Pre-highlight?
All  1-5  6-18
3075.6 In reply to 3075.5
> Then I think if I try to do a similar thing and make
> edges show as selected when a "wireframe" solid
> is selected, then that pushes some problems on
> to the edge selection drill down stage since then
> there will be a bunch of edges that are displaying
> as selected when they really are not selected (as edges).
How about a different color for the halo and highlight for breps when edge only?
> I can probably take a stab at making this work better in v3.
That'll be great, I'm confident that you will make this work smooth and logical.
One other thing I noticed is when one brep is edge only and the other has faces during a Boolean operation you end up in a mixed state, which I believe could be misleading.
Example:
We start off with two solid blocks, one with edges only the other faces and edges.
When we do a Boolean Union we get this.
Boolean Diff
without looking at the object properties panel one would think that it produced a joined surface with missing faces, do you think after a Boolean operation that all faces should be showing for the new brep ?
3075.7 In reply to 3075.6
Hi Danny,
I generally try to avoid using too many different colors for different things.
Often times I think it just leads to people wondering, "why is this stuff some weird other color" instead it actually conveying an easy to understand message.
Also using more colors makes things more likely to conflict with other colors that people want to use for their regular display, for organization or whatever.
Hmm, how about if it will follow the same wireframe state as the first selected object? That will make it consistent with other things as well, like the parent object name for example (if you have 2 different named objects and you boolean them, the new combined object gets the name from the object that was selected first).
3075.8 In reply to 3075.7
It was just something that immediately popped into my head and I just threw it out there :)
Yes, that'll do the trick, thanks!
3075.9 In reply to 3075.8
Hi Danny,
Believe me, I wish I could do that... :) It tends to be a lot harder to try and make everything fit in a more limited set of colors. (or in limited space, limited whatever is more difficult).
Great, I've added that in for the next beta.
The other thing I just added is that if all the original faces of an object are hidden (so the object is in kind of "wireframe mode"), then any new faces like fillets will also get hidden so that the whole object stays as wireframe. Previously just the fillet faces would be showing with the rest of the stuff still in wireframe.
3075.10 In reply to 3075.9
Would a 5 or 10 percent opaque ruin the intent if hidden faces. So a face is hidden and you can turn on a "mouseover" opacity for hidden faces?
3075.11 In reply to 3075.10
Hi Burr, some faint opacity for "hidden" faces could work.
But my display engine does not currently have translucent faces set up to work in it yet. That's something that I am hoping to add in the future.
3075.12 In reply to 3075.9
Yes, we experience that here at work with every project, it's like the customer always wants a circus to happen on a 1ftX1ft area, and when we achieve it they come back and ask if they can squeeze in one more Elephant :)
So we know how you feel.
> The other thing I just added........
That's great! it keeps it consistent across the board.
3075.13 In reply to 3075.11
I thought about the transparency not being there yet, but what about "Glow"? Can something still glow if it is hidden? is the Glow some kind of directx shading thing that is a bit of light being emitted or is Glow just an illusion to my eye with the visible surfaces color change.....So omit all glowing shades from hide routine.
3075.14 In reply to 3075.10
Hi Burr,
I like this idea, but the reason I like edges only is so that I can work through solids on an underlying piece for alignment of features, so having any faces would obstruct. I would like transparency though :) and I can also wait for it.
3075.15 In reply to 3075.14
Yeah I hear you there. I was trying to input on the ability to differentiate between a wireframe and a solid with the faces hidden and how to know to drill down to select those edges. I had heard Michael mention before that he will be adding in these other types of rendering options like transparency (I cant wait), but I always have to chime in. Hoping to get lucky and contribute! I think I have a couple good contributions (if not only one) over the time I've spent here. Just have to throttle myself so I'm not a pester instead of an asset. :O
3075.16 In reply to 3075.13
Hi Burr - re: Glow - the glow effect is something that works along a 2D path, it only applies to curve rendering, not face rendering. So unfortunately it would not help for this particular purpose.
3075.17 In reply to 3075.15
That's cool Burr, I like thread input from other users on the forum it makes more interesting reading, some of the ideas are great and it's better to say it than think it.
Plus we can't allow Michael to get bored :)
3075.18 In reply to 3075.17
Sending good vibes out to his little guy! ♥
Show messages: All  1-5  6-18
