Converting points on a tablet pc
All  1  2-6
307.2 In reply to 307.1
> Question though is how do you convert a point from a corner point to a curve point without using a keyboard?
is there away to do that?
Yes you can :)
When you draw your curve you have a Menu Up Right Corner Page Screen :)
Just Enable / Disable "Make Corner Point" as many time you want
et voila
Have happy Modeling without keyboard ! :)
That's magic all with only the pen or the mouse!!!
307.3 In reply to 307.2
ok thanks but is there a way to do that after you have made a curve/line?
after you finished with drawing tool then say you select the curve/line and show points and then
how do you convert a courner point
307.4 In reply to 307.3
> curve/line and show points and then how do you convert a courner point
To do this, you use Edit/Add pt, and check the "Make corner point" box, then add the new corner point nearby the point you wish to convert.
Then select the old point and delete it - you will be left with just the new corner point.
Eventually there might be some other method to convert an existing point, but for the time being just inserting a new one should get you the result that you want.
307.5 In reply to 307.4
Simple and Tricky:)
307.6
Ok that will do
thanks for the quick responces
I'm no expert by far but I must say this app is soo much fun to use
Show messages: All  1  2-6
