RebuildCurve Error
All  1-2  3-7
3055.3 In reply to 3055.2
Hi~~ Michael
Thanks for apply!
2 files (RebuildCurve.htm, RebuildCurve.js) command is in the folder.
Still the error occurs.
3055.4 In reply to 3055.3
Hi fiveelement, how exactly have you set up the shortcut to run the command?
Another possible installation problem is if you made the shortcut say: RebuildCurve.js instead of just plain RebuildCurve (note, no .js at the end).
To have this one run correctly (as a "command" that has a companion UI file rather than as an "inline script") your shortcut should be set as just plain RebuildCurve with no .js at the end.
Is that possibly what you have run into?
If that wasn't it, can you please let me know which version of MoI you are trying to use it with?
3055.5 In reply to 3055.4
Hi Michael~~~
Thank you so much for the quick response.
Was shown above.
There are still error.
3055.6 In reply to 3055.5
Hi fiveelement, which build of MoI are you using?
It looks like the current RebuildCurve script uses a function that is only in the most recent Oct-19 v2 beta. So that may be the problem.
Try the slightly older version attached here and see if that works.
Also for the next v2 beta there will also be a new Rebuild command that will be a part of the regular MoI install.
3055.7 In reply to 3055.6
Hi Michael
The problem was solved
Perhaps,MoI is previous version.
Thanks you!
EDITED: 4 Nov 2009 by FIVELEMENT
Show messages: All  1-2  3-7
