Capping extrusions, wireframe visibility
3048.1
When you're extruding a 2D shape into a 3D object, is there a way to get it to cap just one end instead just both or neither,
OR
Once it's extruded without caps is there a way to then cap one end,
OR
Once it's extruded with caps is there a way to remove one of the caps?
I there a way to change the display from ghosting to wireframe and back on the fly? When ghosting, is there a way to make the hidden lines show up better, be more visible?
Mark
3048.2 In reply to 3048.1
Hi Mark,
Nope, there's just a simple checkbox for the "Cap ends" option, so it's either both or neither for that one.
Yep, you can select the edges along the end you want to cap, and then run Construct / Planar to build a planar surface through them, then use Edit / Join to join the new plane cap with the main body.
> of the caps?
Yep, this is probably easiest - you just select the face you want to remove (by drilling down, that is when you click a second time on a solid) and hit Delete to remove it.
What do you mean by "Ghost" - do you mean hiding or locking objects?
There is an option in moi.ini for adjusting the opacity of hidden lines, that is under:
[Hidden lines]
HiddenLineOpacity=34
You can edit that to a value between 0 and 255, with 0 being totally transparent, and 255 being totally opaque.
But that will change it for everything, not just in one circumstance.
3048.3 In reply to 3048.2
Is there a way to display 3D objects as wireframes?
3048.4 In reply to 3048.3
Hi Mark,
You can hide all the faces and leave only the edges showing.
In v2 there is a quick way to do that using the Scene browser - go to the Types section and there is an entry there for "Faces" - click on the eye there to hide all faces and you will be left with only a wireframe view of your model.
