make a gear a solid
All  1-3  4-10
3047.4
Have you noticed that the center dips down like you are wringing it? It looks ok to about 20 degrees. I'm going to try something else real quick
3047.5
I think I got it.... I was thinking in the wrong terms for sweep. take a look. you can see that I used the profile of the gear as the profile and created 2 helix curves to use as rails. before when I tried this, I was only using 1 helix as a control curve for extrusion... what do ya'll think?
3047.6 In reply to 3047.5
Hi nc dave. I was just going to post for you the top view of a sraight line sweep. The red is the old sweep path. The green would have to be the new one to have it stay flat on the edges. Looks like you have that figured out though.
3047.7 In reply to 3047.5
Hi Dave, your 2-rail sweep results looks great!
Is that a solution for you then? Please let me know if you are still stuck.
3047.8
yes, that is the solution. Its so fast. I think I can make gears in about 50 seconds. When I get my steam punk mecha done, I'll post.
Thanks for all the help and all the effort you put in with your uses. this forum is amazing. I hope MoI becomes what you want (profitable, etc.). I know I will continue to be a supporter.
3047.9 In reply to 3047.8
Useful thread for reference and lovely work Dave.
Mark
3047.10 In reply to 3047.5
Another way too. 2 rail sweep: use 1 helix curve + 1 line from centerpoint to centerpoint.
Show messages: All  1-3  4-10
