A feature in history system, please - tracking of a snap.
All  1-3  4-8
3036.4 In reply to 3036.3
Hello Michael Gibson!
And thank you for reply!
Basicly my wish was to track yes tangency to the snapped curve.
One more suggestion in the history theme: Is it possible to do track also weight of this curve?
Maybe also a weight of blend.
3036.5 In reply to 3036.4
More pictures:
It shows structure of blend curve.
It is very cool that history updates while i am draging around attached lines.
You see real time change in points and how they maintain continuity with lines.
3036.6 In reply to 3036.5
Maybe a first solution to the problem is to add functionality where selecting a blend curve
and toggling on history in a panel.
Then it gives attributes as were available when constructing these curves: Bulge and Continuity.
Maybe it could also recognize when similar history type is handled over multiple selected blend curves.
3036.7 In reply to 3036.4
Hi Allan,
Unfortunately that's not easy to do, since the Conic command does not take any weight parameter as part of its input, it only takes 3 points.
So that means the only history that is recorded for it is 3 point x,y,z locations and not any other factors.
Yeah the "Bulge" factor for blend is tracked currently - it is reapplied when you move the input curves into blend around.
This one I do have some hope of making the bulge factor editable in an enhanced history edit function in the future.
3036.8 In reply to 3036.6
Hi Allan,
> where selecting a blend curve and toggling on history in a panel.
Yup, that's definitely something that I want to add in the future which would be a major enhancement for History.
The only problem is that it will take quite a lot of work to make that happen.
I do hope to make some progress on it in v3 though!
Show messages: All  1-3  4-8
