Indie / Unity is free!
All  1-7  8-9
3035.8 In reply to 3035.7
I suppose yes :)
http://www.unifycommunity.com/wiki/index.php?title=ObjExporter
Based on ObjExporter.cs, this "wrapper" lets you export to .OBJ directly from the editor menu.
This should be put in your "Editor"-folder. Use by selecting the objects you want to export, and select
the appropriate menu item from "Custom->Export". Exported models are put in a folder called
"ExportedObj" in the root of your Unity-project. Textures should also be copied and placed in the
same folder. */
3035.9 In reply to 3035.8
Sounds good. For 3D-PDF use a light vegetation can be very useful.
Micha
Visualisation for Designer and Architects | http://www.simulacrum.de
Show messages: All  1-7  8-9
