ArraycrvPLUS
 1-18  19-38  39-58  59-70
3034.19 In reply to 3034.18
I'm not positive, but I've a feeling that what Jesse's referring to might be a feature within Matrix?
Matrix is a Hi End Jewellery Plug-in that uses Rhino as it's engine.
http://www.gemvision.com/html/products/matrix/matrix.html
I don't have Matrix, but a friend of mine does, so I've seen first hand some of the fancy things it can do.
There's another Jewellery Plug-in for Rhino called RhinoGold & that might also have a similar kind of feature?
http://www.rhinogold.com/en/
Again I don't have RhinoGold, but I've seen some of the features within their Tutorials.
http://www.rhinogold.com/en/videotutorials.htm
Hopefully some of those links might help to explain what Jesse is after?
regards Colin
3034.20 In reply to 3034.13
I see what you mean... it's not out of the question that we'd run into a situation like your example.
I think your 1st version using "distance along the path curve" would accomplish the desired result.
But... could the object's "normal" relationship to the surface still be maintained?
Could the objects be uniform in size as well as graduated in size? A lot of times, the stones will be the same size.
Right now, we work with the diameter of the stones and the length of the curve to determine
the spacing of uniform objects. If the array doesn't work out with the desired spacing, then we have to either
change the length of the curve or the stone size, each dependent on constraints dictated by
the shape and size of the model as well as where we want the stones to go on the model.
Would it be possible to scale a uniform in size bunch of objects to fit a certain spacing along a curve
while placing them normal to the surface? Probably too complicated?
Colin's assumption is correct. I know Matrix does the kinds of things that ArraycrvPLUS does, but I'm not sure about RhinoGold.
I'll dig up a model as an example to send to you. I hope you don't think I'm asking for too much... :-)
I just want to explore some options because I don't know what's technically outside of the realm of realistic possibilities.
Jesse
EDITED: 29 Oct 2009 by JESSE
3034.21 In reply to 3034.20
While this is being discussed, Has anybody tried the scaleArray in this release. I'm on a computer where it just flashes up for a second then goes away? No need to go nuts till I test it on a few other computers. I re-downloaded it to be sure it hadnt been corrupted on my system or something. :O
3034.22 In reply to 3034.20
Hi Jesse,
Yeah, that's probably doable, did you see the previous link to the new "Align to surface" function for MoI's regular array curve function? (here) - does that do what you are talking about here? If so then it would be possible to do the same thing.
Does this kind of "Gem Array" function always involve a surface and a curve 100% of the time, or are there situations where you want to do something on a curve only and no surface is involved yet?
Well, they could if that would be how it is supposed to work!
I'm just trying to gather information on how you would expect for this kind of thing to function.
The more exactly you can describe how it is supposed to work, with specifics like what inputs are required and what options are required, etc..., the more chance I have of actually being able to make it work at some point.
> length of the curve to determine the spacing of uniform objects.
So are those the parameters that you would expect to give - a diameter value and a spacing and a curve for the path, and a surface for alignment?
That would be great, it helps a lot for me to see an actual example of how it is supposed to work.
I don't know yet, I still don't entirely understand exactly how it is supposed to work yet, so before I actually know that I won't really know if it is a hard thing to do or an easy thing to do.
The more information you can give me on what parameters you want to give it, what stages you would expect for the command to have (like an "pick path curve step", a "enter diameter step", stuff like that), and examples of results would all help!
It's pretty clear though that it would be a special kind of "GemArray" function and not likely something that was built directly in to the standard array. That's because it seems like it is focused on a particular shaped object that has a circular/diameter type aspect to the shape rather than just any old random shape like a box or whatever.
3034.23 In reply to 3034.21
Never Mind. Forgot there were instructions. Doh! :O
3034.24 In reply to 3034.23
Hi Burr, yeah don't forget that you need to include a point object with the things being arrayed, since that is used for the center point of the scaling.
3034.25 In reply to 3034.19
Hi Colin,
It kind of helps with the general idea, but it's tough for me to sort through all their tutorials to try and find the description of this one particular function.
I kind of need it to be broken down and described in more specific detail to have a shot at making it work.
Things like a step-by-step description of what each stage of the command is supposed to do, like what inputs are collected, and then of course a description and some examples of what output is generated.
It's hard for me to just guess at all that stuff since I don't really understand enough about how it is used.
3034.26 In reply to 3034.25
No probs, to be honest I'm not overly sure on how it all works myself, so I'm no help in describing it in detail.
I'll see if I can wangle my friend into doing a small video for you of it working in Matrix.
regards Colin
3034.27 In reply to 3034.22
I have tried the new Align to Surface option and think it's fantastic! It really makes MoI a lot
stronger for jewelry modeling, so if you can incorporate it into a Gem Array function that would be
wonderful.
For what we're talking about, a curve is always involved when arraying gemstones.
(gemstones positioned normal to the contours of a curvy surface).
For flat settings, you can just array the stones a certain distance from each other along a curve that's
sitting on a surface, using the surface only as a visual reference because you know the z height will be constant.
In Rhino, for arraying stones on rings, extracting an isocurve rather than projecting a hand drawn curve is used sometime
because it provides a path that conforms exactly to the shape of the channel that the stones are to be located in.
For other models that may have a curvy top surface but a flat back, ex. a pendant or broach, a construction curve can sometimes
be offset, flattened in Z and then projected to a surface to locate the path curve. (the rebuild curve function is invaluable in shaping and positioning these curves)
Yes, those would be the main parameters, but you could also include an offset distance relative to the surface, in case you wanted the stones to be buried into the surface a few fractions of a mm.
This is probably kind of "out there" but would it be possible to do something like a grid array but have the objects lay out on a curvy surface, positioned normal to the surface?
>The more information you can give me on what parameters you want to give it, what stages you would expect for the command to have (like an "pick >path curve step", a "enter diameter step", stuff like that), and examples of results would all help!
(I remember that in Rhino, sometimes the array would go all crazy because the area where the stones were being placed was actually a poly-surface , so we'd create a less complicated "dummy surface" in it's place, to align to).
I don't know if the model that I'm attaching is a great example, but I hope it will give you a better idea of how it should work. *
Ideally, I'd like to fill as much of the surface area as possible with a curved line of diamonds, so perhaps if you designated a starting size and an ending size, then select the path curve, the surface for alignment and the spacing... the stones could be graduated in size between them?
Even as I write this, I think it seems impossible...:-)
I will get a step-by-step description of the process from a friend who has Matrix.
Jesse
*(Side note: It was a challenge to position the original stone normal to the surface.. I ended up drawing a straight line normal to the surface and then moving the stone to the end of the line and then using construction lines as a guide, rotating it until it was tangent to the line and then moving it along the line until it looked like it was on the surface. Is there an easier way to position an object normal to a surface other than drawing it in place?)
Edit: After getting some sleep, I discovered this morning that using the Keep Cline script made it a lot easier to place the stone normal to the surface. I didn't need to draw a line. :-) -JDK
EDITED: 31 Oct 2009 by JESSE
3034.28 In reply to 3034.27
Yes! as Jesse said, a sort of 'put instance on normal surface', instance (gem or any solide) with a 'distance box/cylinder' (with +- tolerance?) for distance with other instance and other solide/surface except the choosed 'put on surface' and a 'placement point' relative on 'put on surface'.
Recently have the prob: follow a path with 52 stone = array curve always fail (see pict); certainly (because Im a noob with MoI and) because curve was wrong... (?)
so have a tool to 'paint instance on surface' can be great.
3034.29 In reply to 3034.27
Hi Jesse,
> it should work.
Yup, that helps give me some kind of reference, thanks.
So seeing that brings up another question - would you want to specify this kind of thing by telling it a distance to use between each item, or would you want to tell it something like the total number of items and have it figure out the distances automatically?
The second type (give number of items and have distance calculated) may be quite a bit more difficult for me to make in this case, so that may be something that I could not make initially at least.
What I'm thinking is that you could specify a previously drawn circle as one of the inputs to the command.
The center of the circle would be used as the "base point", for the spot that will correspond to the location on the surface. So you could position the stone in relation to the circle to control a vertical offset. The circle would also control the diameter as well.
Maybe, but it's a lot harder to think about how that would work. I'd like to focus on making a curve one work first and see how that goes.
Oh yeah, how are changes in size supposed to work? Would it work to specify a scale factor that is applied to each instance? Like for example you would put in Scale factor: 0.9 and that would mean that each item would be scaled down by 90% in size from the previous one. That's probably the easiest way for me to make it function, but that also means that you don't have a specific control over the size of the very last one, its size would be dependent on the number of items that were produced.
3034.30 In reply to 3034.29
Well, it would be nice to specify a distance between objects since the distance between objects would have to be checked anyway after the array is complete, in order to know whether you've created a viable model. Either way, it's gonna be a little bit of trial and error, getting the right distance between, number of, and size of, (the object ) to array along a particular path curve on a surface, so would having as many variables as possible to edit help with the process?
>The center of the circle would be used as the "base point", for the spot that will correspond to the location on the surface. So you could position the stone >in relation to the circle to control a vertical offset. The circle would also control the diameter as well.
Makes sense to me!
I like your idea to designate a certain percentage to scale each instance, but if anyone else has any ideas, please feel free to chime in... :-)
Jesse
P.S. Michael, I sent you some info by email that will hopefully answer a lot of the questions we're discussing.
EDITED: 2 Nov 2009 by JESSE
3034.31 In reply to 3034.30
Hi Jesse,
> since the distance between would have to be checked anyway
Well, that sounds good because that way would actually be easier.
> you might want 3 the same size, followed by 2 a bit
> smaller and then 1 smaller still, so perhaps the scaling
> thing isn't as easily predictable as the distance
> between objects,
Aha, well this is the kind of detail that is great to find out about! :)
So one idea on how to control that more exactly could be to provide multiple base circles arranged in left to right order like this:
and then that would define the size of each instance in the array. You would put the actual Gem/object to be duplicated inside the first one to the left.
The spacing between these initial circles would be ignored (because you will be specifying the distance as a parameter in the command), it would just take the sizes from them.
Is there something like a standard set of sizes? If so then I guess you could have some circles set off to the side made up for those sizes, and then copy them into place into a line like the above to control which ones would be used.
Would something like that work?
3034.32 In reply to 3034.30
Hi Jesse, also just a bit more on distances.
The way that I was thinking you would probably want the distances to work is to make the distance between each circle be equal. That's the length of the shortest line between each circle, like this:
Would that be good?
That is not exactly the same thing as trying to make "distance traveled along the path curve" be equal, but from what I'm understanding you probably want that more "direct distance spacing between each circle" to be what is controlled, is that correct?
What about when the circles are not all in the same plane because they are rotating to adapt to the surface normal, would it still be that "shortest distance between 2 circles" to make equal even though they were tilted at different angles?
Or do you really actually want "distance as traveled along the path curve" instead of that?
3034.33 In reply to 3034.32
Michael
The array along curve with normals to surface is a wonderful idea. I feel that at this juncture, perhaps, it is prudent to look ahead a little. The next step, of course, is to add prongs into the mix. Because, after you get the stones where you want them...your going to need prongs to hold them in place. This brings up a whole different set of parameters as well as problems. Perhaps the simplest way to achieve adding the prongs into the equation, while taking into consideration the necessary spacing requirements, would be to add the prongs to a stone, group it, and array the prongs and the stones at the same time. This of course assumes that the stones and the prongs are consistent in size. If not, it leads down the road of necessitating sliders or multiple check boxes or places to designate specific stone sizes within the array to change the shape and size and distance between the stones either pre or post applying them to the surface. (that was a long winded sentence but hopefully you can grasp the entire concept) Pave' is the ultimate test...and nightmare. Overlapping stones and prongs must be found and eliminated, or some type of system that the program arranges the stone placement in the most exacting and specific manner must be designed and implemented.
David
3034.34 In reply to 3034.33
DDB just touchs on a point. I wanted to chime in on the scale thing with "Having a starting and end parameter setting, then a scale factor number of like 1-10 that is applied to the value of the start and end sizes. But then I realized that the distance between the array should be the arbitrary number as in the real world, the stone is the size that is not the variable.
So if I was a jewler creating an array on a ring, I would choose my ring shape and the "Stones" that go on it (simplified of course) and the array would be designed and adjusted by the stones. So it seems "Scale" or size at each point, would be primary, and the rest adjusts per that.
So it seems that Michael, laying out a "prebuilt size grid", then choose the size that fits the stones to be used in the array, would be more viable.
(Or was this already decided and I missed it following along)
3034.35 In reply to 3034.31
You're asking some good questions..some of which I'm not sure of the answer!
The multiple base circle idea sounds like it might work. Would you be able to create
your own circles and designate them as Object 1, 2, 3, etc?
I would not say there is a standardized set of sizes, stones are measured down to the tenth of a mm
so there are 100's of different sizes used.
Jesse
3034.36 In reply to 3034.35
Another approach would be arraying them (both prongs and gems) along a representative created uv surface and flowing everything back to the original surface as is currently done in Rhino. BUT there is the distortion thing that must be overcome.
I'm a big fan of flow along surface.
David
3034.37 In reply to 3034.32
This is the part I'm not sure about. It would seem that the distance along curve would only give you so much accuracy when the array is aligned
to a surface. However, the area of the stone (that needs to be spaced correctly) which is most critical is the "girdle" which is the widest circumference
where the top and bottom facets meet on the sides. So if a circle was grouped to the stone there, that might do the trick.. So if it was the closest points on circles grouped to the stone, that might work. In Rhino I remember grouping a point that was placed at the right level inside the stone to line things up for an array, so that might be another option.
As for prong placement that's going to be a tough one because when the curvature of the path curve changes, so does the spacing. I do it manually, creating some 3d scaffolding by offsetting curves and finding intersections and then copying and pasting circles to mid-points of lines I've drawn.
In this example, you'd need to change the diameter of the prongs just a little, making them smaller or larger or move them in or out a tiny bit, where ever the bend in the curve bows out or curves in more radically, so they (the prongs) cover the stone properly, so it's never an exact science. You kinda do whatever works while trying to fool the eye into thinking it's more uniform than it really is.
Jesse
EDITED: 3 Nov 2009 by JESSE
3034.38 In reply to 3034.33
Hi David,
> the mix.
Are the stone placement and prong placement intertwined with one another?
I mean for example, would you want to move a stone to a different position in order to accomodate a prong? Or are the prongs something that are meant to always fit around the stone placement and not require altering the stone placement?
If it's more that the stones are the "primary" thing and prongs only accomodate them, then I'd like at the beginning anyway to focus only on placing the stones for a bit and see if I can actually make something for that as a starting point or not.
I don't really know very much about jewelry so it's a fairly tough area for me to work in, there is a lot of stuff to absorb and I'm not very confident about trying to accomplish too much all at once. So if I can focus on things one step at a time that is probably going to be how I could possibly make some progress.
Show messages:  1-18  19-38  39-58  59-70
