Hi Alex, so what happened there is the script set the line width property for the display and that property gets saved in the moi.ini file.
If you have something like that happen again where something is still changed after you restart MoI, that definitely means it has been saved in moi.ini .
In MoI v2 there is an option to make it easier to edit the moi.ini file directly, that's under Options > General > Edit .ini file button.
