Thick line
All  1-3  4-7
3033.4 In reply to 3033.1
Hi Alex,
this should help, just define script below as a command part of shortcut and run this newly defined shortcut
script:moi.view.lineWidth = 1;
Petr
3033.5 In reply to 3033.4
THANK YOU! ALELUIA! :) lol,thanks again my friend.This is perfect.I can finally work again,have a great day.
Alex Cruceru
3033.6 In reply to 3033.4
One for Petr's MoI page?
3033.7 In reply to 3033.1
Hi Alex, so what happened there is the script set the line width property for the display and that property gets saved in the moi.ini file.
If you have something like that happen again where something is still changed after you restart MoI, that definitely means it has been saved in moi.ini .
In MoI v2 there is an option to make it easier to edit the moi.ini file directly, that's under Options > General > Edit .ini file button.
Show messages: All  1-3  4-7
