Export Script
All  1-3  4-5
3025.4 In reply to 3025.3
Hi Crusoe, I think I get the idea and scripting something along those lines should be possible.
Still need a few details to be cleared up though -
> I'd like to hit a button, "export all" (or maybe all visible)
Which one, everything or skip hidden objects?
> chose the filetype
This part is probably a bit difficult since there is not any kind of "filetype" picker set up, only things to get a full file name. So probably the script would have a fixed file type associated with it and you could edit the script to control the file type.
> and have it save each named group to a different file with
> the group name as part of the filename.
Into which folder would you want the files saved to?
Files don't normally just get created on the computer with a single simple isolated name, they need to go into a folder somewhere.
Or do you mean that the object names will include a full path with a folder name in it?
3025.5 In reply to 3025.3
Hi Crusoe - also are you going to be exporting to a mesh file format?
By default the meshing dialog will be shown on every separate export when going to a mesh format.
Is that what you want, or do you want to have some fixed settings specified in the script which will get used and no mesh dialog shown? That's the other possibility.
Show messages: All  1-3  4-5
