Imprint Solid?
All  1-7  8
3024.8 In reply to 3024.7
Hi Mark,
> You probably had a particular arrangement of curves for
> that, like a 4-sided boundary?
Yes, the particular extrude was four sided.
> Unfortunately that would not work in the general cases,
> it would only work if you had a 3 or 4-sided boundary.
Yes, understood.
> For now you can run Boolean Union on the result with the
> shared internal wall, it should fuse those pieces together
> and remove that part.
Jeez I'm an idiot...
I manually searched and destroyed all the internal walls I had created. If there is a hard way to do something, I'll find it!
Mark
Show messages: All  1-7  8
