UI weirdness
3018.1
I have installed the latest beta on tabletpc and got this strange look of transform and construct palettes.
Note it doesn't depend on a side pane position (right or left).
Petr
Size: 20 KB, Downloaded: 8 times, Dimensions: 413x220px
3018.2 In reply to 3018.1
Hi Petr, thanks for reporting this bug.
I happened to notice this recently myself and tracked it down yesterday.
It appears to be a bug in mshtml.dll that happened to be triggered by the new asterisk (*) display at the end of the filename for changed files.
Can you please try updating the file \ui\SidePane.htm inside of the new beta's install folder with the new version attached here and see if that solves it?
That should hopefully still give the * display on the filename but avoid the weirdness.
3018.3 In reply to 3018.2
Yes, it solves not only that problem but also another one which I thought it wasn't a bug :)
I mean the vertical scrollbar appeared when I clicked a transform or construct palette header while some other commands (like Line) was running. Now, there is no vertical scrollbar - some other palette (like View) collapses instead. Many thanks!
Yes, it does.
Petr
