Fixed color for curve creation ?
All  1-2  3-4
3010.3 In reply to 3010.1
Hi PaQ, why not just use a style that shows up better for the curve rather than using a style that does not work well?
For example, set your current style to a style that has color=black instead, then draw whatever curves you need and they will be displayed as black.
But I'll take a look at adding in an option to moi.ini for a "CurveColorMode" similar to the ones for Surfaces and Edges.
3010.4 In reply to 3010.3
I like to assign colors while modeling, it helps me a lot to visualise stuffs. So off course I could switch to the black style every time I add a curve, but it's an extra step I would like to avoid, if it's possible.
I do not like the default black style, because I'm using a custom lighting setup (you know, the subtil metalic one), and it burns the pure white surface a little bit, so my default style color is a light grey (220.220.220)
Thanks a million :)
Show messages: All  1-2  3-4
