Hide only seams generator
All  1-9  10-11
3003.10 In reply to 3003.8
Hi Eddi, yeah I think Jonah has it described well above.
If you use Edit/Separate on that object, you should see that there are 2 pieces there that you can drag away independent from one another.
A seam edge is when there is the same 1 surface on both sides of the edge.
It is possible for edges to change their configuration after things have been sliced up in booleans like in your case there.
3003.11 In reply to 3003.3
>To do that, set up the following as the command on a keyboard shortcut:
That's great!!
Marc
Show messages: All  1-9  10-11
