New Zooming Script
All  1-4  5-9
3001.5 In reply to 3001.4
Hi Burr, so you mean a keyboard shortcut that sets this this option here:
That's possible to do with the following script set up on a shortcut key:
script: /* Set view button sensitivity */ moi.view.zoomButtonSensitivity = 0.1;
But part of the action of that zoom button takes into account how far you have moved the mouse from the initial click down point. If you only move it by a few pixels you should get a very small stepping zoom in effect already (like in the video above) without needing to hit any keys.
But if you want to set different sensitivities with different keys, use the shortcut above and you can change that 0.1 value at the end of the script to different numbers for different keystrokes.
3001.6 In reply to 3001.5
Thats it Michael.
Thanks. When I get in really close I feel better with the sensitivity drop so this will help me.
Burr
3001.7 In reply to 3001.5
>>>script: /* Set view button sensitivity */ moi.view.zoomButtonSensitivity = 0.1;>>>>
Could I see one example added to this script that would toggle the sensativity back to a default value, say of 1, if it was already at .1
Thanks for the time on this,
Burr
3001.8 In reply to 3001.7
Hi Burr, no problem.
If you want to have a shortcut that just sets it directly to 1 on a certain keypress, use:
script: /* Set view button sensitivity */ moi.view.zoomButtonSensitivity = 1.0;
If you want just one single shortcut that flips back and forth between 0.1 and 1.0 every time you press it, that is also possible, here is that one:
script: /* Toggle view button sensitivity */ if ( moi.view.zoomButtonSensitivity != 1.0 ) { moi.view.zoomButtonSensitivity = 1.0; } else { moi.view.zoomButtonSensitivity = 0.1; }
3001.9 In reply to 3001.8
Yes the second was what I was after.
I'll study the different parameters, ie;
() and {} added that allow me to do the If/Else myself without bugging you for something so simple. :O
Thanks again!
Show messages: All  1-4  5-9
