Text and Extrude Command
 1-18  19-23
2999.19 In reply to 2999.18
Suddenly the option box has mucho roomo. Cant wait to see what I find! :)
Thanks Michael.
2999.20 In reply to 2999.19
Hi Burr,
Yeah it used to be fixed to a hard coded pixel size on startup. That could be too small if you were on a higher resolution display and had some larger font sizes for the UI text size.
Now it should hopefully adapt better to your font size.
2999.21 In reply to 2999.19
Hi Burr,
By the way, please let me know if it seems too big!
Hopefully now it should start out big enough to avoid needing a scroll bar for most systems though.
2999.22 In reply to 2999.21
It looks really nice. I just reviewed it on a 17, 19 and 30 inch monitor and didnt feel off in any way. I set a font size of 9 for my use and all looked well. The 17 produced "1 line" or so at the bottom that enabled the scroll bar, like the "lighting button" in the view tab. But it didnt seem odd. And I could resize it! Maybe a setting save that remembers the resized window state value would alliviate any issues for all scenarios. So you have a great all around setting now, but if I drag it a bit bigger on my small monitor to avoid scrolling, it returns to the default state. Can it write that value on exit?
2999.23 In reply to 2999.22
Hi Burr,
Yup, I think that should not be difficult. I probably should set it up so that any resizeable dialog (currently Options and Edit Styles are set up like that) gets its size saved in moi.ini automatically.
Show messages:  1-18  19-23
