extrude command
2998.1
Hello!
There are some problem with extrude command in this case... it dont works.
I would like to extude the faces but actually all the same the polylines dont work as well.
threre is no cap of final result.
2998.2 In reply to 2998.1
Hi Andras,
Your points are not touching in this area. If you turn on control points for these 2 entities and then window select that corner point (Actually 2 points):
Then switch to the right view and hit the reset view icon you will see this:
Go back to the 3d view and select the little vertical lines bottom point and snap it to the horizontal end point and it will extrude as solid.
2998.3 In reply to 2998.1
Hi andras, looks like Burr has you covered here, thanks Burr!
Usually if an extrusion will not cap it means either the curve was not planar, or not closed, or it possibly has a self intersection (crosses over itself) in it somewhere.
Please let me know if you need any more help with this one.
2998.4
thanks guys everything ok
