Is Moi geometry better than Rhino?
 1-15  16-26
2991.16 In reply to 2991.15
>>>here is an example from maya, modify>convert>subdiv to NURBS.>>>>
And hows the resulting NURBS model from that conversion??
2991.17 In reply to 2991.16
Burr wrote : "And hows the resulting NURBS model from that conversion??"
Now that's the real question, isn't it? Amapi also had a sub-Nurbs converter but the result was not on par with T-Splines...
2991.18
<< One of the difficulties though is that sub-d / box modeling has a fairly different kind of toolset than NURBS modeling, so it would mean introducing quite a number of brand new tools to work on the polygon cage. That means it will take quite a bit of work and that's why I don't know when it will happen.>>
Maybe a way to import the sds cage would be a great start :) there are allready so many poly modeler around.
Now, if you come with a new poly modeler, with the same 'MoI Touch', it would be amazing !
2991.19 In reply to 2991.18
"Maybe a way to import the sds cage would be a great start"
WOW, would that be possible?
2991.20 In reply to 2991.7
Well, you could just make it more generalized then. MoI already has the ability to push and pull points, curves, and surfaces, with and without the precise transform tools. Thus editing a sub-d cage would be very much like editing the hull cage of a surface now. If the purpose is to use this cage to generate NURBS surfaces, then the only real additional tools I could see as being needed would be a fast way to add edge loops and some loop and ring selection. And even these tools would be of use for NURBS work; adding a loop to a surface would just be a very fast trim and such.
The workflow I envision would be two ways of entering into this sort of cage edit. One would be to create a box (that would be making a sphere). The next would be to do something akin to the Network tool, only you end up with a cage controlling the surface instead of the surface directly. From there you could pull the points and edges around, use the new tool to add loops, and box model your way around. Tools like Extrude or Chamfer would work off a face or an edge much the same as it does on NURBS surfaces. The tools that can't work on a surface or solid would likewise not work on a cage. And I don't really think it'd be safe or wise to let Booleans work on them (way too messy to make it work consistently).
Once you like it, you could then drop the cage down to a surface and have a nice, smooth NURBS surface made from the more gooey and sculpture sub-d methodology. It wouldn't really be a full-fledged subdivision modeling solution, but that isn't a big deal I don't think.
Ideally, one could also take a surface and push the same Cage Create button and get a lower-res cage around that surface (or even solid). One of the main issues I have with trying to push or pull surfaces generated in MoI from lofts, sweeps, or networks is that the control point density is often huge. Without a soft-selection or free-form deformation cage, modifying these surfaces naturally is a pain. There's also no way to deform things (like a bend or twist) without doing it the very tedious and unnatural way (moving point by point). If I could just toss on a cage, such things would be cake; add in a soft-selection falloff and I think I'd be in heaven.
2991.21 In reply to 2991.20
Hi Keris, yup what you are talking about there definitely make a lot of sense!
The only thing this is this part:
does not necessarily make things "less work" or less time to develop, it actually tends to take more design time work to try and make existing commands that work on NURBS to also be multi-targeted and apply to a polygon cage as well.
And I also worry about it possibly being an unpredictable mixture, like if Chamfer worked on a polygon cage but Booleans did not that tends to make for a rather inconsistent overall flow to things, I'm not really sure if that would be the best way to handle things.
Typically existing functions in MoI are very oriented towards precision and using the mouse to be able to do object snaps and stuff like that, but usually a sub-d modeling tool's functions like extrude are wired up to be less precise and more just give you some quick sculpting like feedback as you wave the mouse up or down instead of being a "snap to objects" kind of thing. So to make the same kind of sub-d modeling feel I'm not sure that you would get that by using the same existing extrude command.
Anyway what you are talking about there are definitely some great ideas, but still are very much in the realm of requiring quite a lot of work, so that part that I mentioned about it taking a lot of effort and not knowing when it will be possible to happen still applies.
2991.22 In reply to 2991.20
Hi Keris,
<<Well, you could just make it more generalized then. MoI already has the ability to push and pull points, curves, and surfaces, with and without the precise transform tools. Thus editing a sub-d cage would be very much like editing the hull cage of a surface now.>>
I really don't think moi tools allow any freeform point pushing for the moment. Using the precise transform tool is way to slow, and the selection/drag system is not accurate enough for this kind of job îmho.
I do like the idea to have a unique toolset between poly and nurbs too, but that would be a hell job I guess.
2991.23
I just like the idea of a Michael Gibson brand or spin on an SDS modeler.
It doesn't have to be within MoI, it can be a seperate program all together.
Hopefully using the same GUI setup (IExplorer / HTML/Javascript) etc.
Now that Silo has fell off, I'd love to see something step up to the plate and fill the void, Michael has proven being able to develop similar GUI elegance in MoI, I'd certainly be interested to see his spin on SDS modeling.
That's a lot to ask of one person however, 2 totally seperate products, both demanding attention and updates by their devoted user base - so I guess that toolset would have to be within MoI if there is to be any chance of fruition...
With the tools I have, the NURBS and SDS toolsets are always compartmentalized; you can create objects using NURBS methods OR SDS, rarely can you create a NURBS object from an SDS input.
You choose the methodology based on the type of model you're creating, mechanical or character for example. I don't see a problem with the separation.
However being able to create NURBS from SDS would be interesting, something I imagine the TSpline users already enjoy I certainly wouldn't turn down the ability of being able to do that.
Anyway, again, I'd love to see Michael's spin on SDS...
-Will
2991.24 In reply to 2991.21
Oh, most definitely it will take a lot of work! I didn't mean to sound like it wouldn't. My comment about "make it more generalized" was intended to be about weighing down the interface and workflow with specialized tools. All this would require a boatload of new under the hood work to make happen. Most, if not all, the commands would have different actions to get the same interface results as the NURBS tools. But I was seeing more of the interface being much the same (just maybe some more options for the cage tools if needed) so that the much of the same workflow can happen and you don't end up with that compartmentalized feeling a lot of other programs have; it's rather annoying to find that you can do this or that command on one type of object but not another. The ones that raise my ire are usually a generalized concept like an lattice deformation.
Well, you can already just click and drag the extrude tool. ^_^ And having the precision is also a good thing when doing hard surface models (that you want to have as sub-d meshes for import into something like ZBrush). Personally, I think the tools are a good 90% there for adapting, interface and workflow-wise, to a typical poly/sub-d modeler. The only times I feel like I want a more gooey feel is on fillet/chamfer (something like being able to click and slide the mouse while the fillet updates in real time).
Plus holding Alt turns off snapping temporarily; although that turns off ALL snapping, including things like the auto-construction lines with tend to be the only way to get things to extrude in the 3D view without flying off to be on the ground grid. I think a good way to avoid that would be some sort of fast way to temporarily pin the construction plane. Like little squares running in the XYZ directions off the selection. Click the square and the CPlane would snap to that until you start another tool or select another square to change things.
As for the lack of Booleans, I only say that because Booleans are kind of the bane of poly modeling; if you don't have overly dense meshes (that are rather impossible to deal with), you end up with a lot of odd N-Gon shapes that just get more and more painful to deal with and clean up (and which subdivide like utter garbage). Now, if you had it so that the Boolean would intelligently snap the mesh cage vertexes to avoid adding any extra vertexes, I'd say you'd have something worthwhile. Something where you could control a slider to see which shape has the more bias to it's original vertex position. Of course, if you don't prepare the two meshes well, then such a system would likely be useless (one has more edge density than the other, etc). In that case, the only option is to toss out edge loops or add in new ones, both of which will change a sub-d surface. I guess the only best way is a compromise. (Booleans are sooooo much nicer in NURBS.)
2991.25 In reply to 2991.22
Oh, it's there. If you separate a solid into it's surfaces, clicking the Show Points button will happily show the points. Which you can click and move just like points on a curve. It's just that doing so is tedious beyond belief due to the density of the isoparams. And I agree with you about the selection issue; MoI really needs a nice lasso select tool. ^_^
2991.26 In reply to 2991.24
Hi Keris,
Yup! :)
That's one of the main reasons why people who said that "NURBS are dead" and that they only needed sub-d surfaces _only_ were being kind of shortsighted. (although it may have applied to their own particular work, just not every kind of 3D model)
But of course that's also why I have focused more effort for MoI into things like the boolean toolset and not on a surface point manipulation toolset yet.
Show messages:  1-15  16-26
