Browser icon (eye/lock)
All  1-7  8-12
2990.8
Hi Petr and Michael,
Just an idea: the lock icon could be on the right side of the column, only appearing when needed.
It could 'eat' up a bit of the text label space while on.
Marc
2990.9 In reply to 2990.7
Hi Petr,
> Hi Michael, do you have a set of those alternate icons?
No, I don't have any set up yet, that was just a test run that I posted previously but it turned out kind of better than I had thought it would.
So I think I'll give that a try.
That would just be an alternate display for the mixed state though, it doesn't turn it into 2 column controls.
2990.10 In reply to 2990.8
Hi Marc,
One problem is that not everything has the text label immediately next to the status column, for styles there is a swatch next to it, and for groups there will probably be a +/- control next to it before the name text label.
2990.11 In reply to 2990.10
I'm not sure if I've explained it well, I meant at the rightmost side...
Marc
2990.12 In reply to 2990.11
Hi Marc, I see - that makes more sense.
But I already have something else planned for that spot - some things will likely get a arrow there (similar to the one Styles header part, but only showing up when the mouse is on that item's line) that will open up a menu with some additional actions and stuff related to that particular slot.
Show messages: All  1-7  8-12
