Browser icon (eye/lock)
All  1-5  6-12
2990.6 In reply to 2990.5
Hi Petr, one other thing I was thinking of was to possibly have the locked/unlocked mixed status displayed with some tiny icons, like this:
I usually try to avoid making really teeny-tiny things but I guess in this case it may be better than stacked over top of each other.
> I thought the "Isolate function" (right click on Hide button
> in the command palette) was a shortcut to doing a sequence
> of commands Invert + Hide.
It's really meant to be a method to hide all objects that are not selected, leaving only the selected objects shown so you can concentrate on them.
Previously the closest thing to that was Invert + Hide, but yeah Invert + Hide has different behavior with locked objects because locked objects do not get selected with the invert.
There's also another difference between Isolate and Invert+Hide - Isolate actually stores an internal snapshot of the state of all objects right before changing them, so that you can click it again later and get back to the pre-isolate state. This was actually the main reason to make a special isolate method.
2990.7 In reply to 2990.6
Hi Michael, do you have a set of those alternate icons? I could try how they fit to various screen resolution. But I guess if you are not loaded in favour of two-column style :) , you can leave it as it is. -Petr
2990.8
Hi Petr and Michael,
Just an idea: the lock icon could be on the right side of the column, only appearing when needed.
It could 'eat' up a bit of the text label space while on.
Marc
2990.9 In reply to 2990.7
Hi Petr,
No, I don't have any set up yet, that was just a test run that I posted previously but it turned out kind of better than I had thought it would.
So I think I'll give that a try.
That would just be an alternate display for the mixed state though, it doesn't turn it into 2 column controls.
2990.10 In reply to 2990.8
Hi Marc,
One problem is that not everything has the text label immediately next to the status column, for styles there is a swatch next to it, and for groups there will probably be a +/- control next to it before the name text label.
2990.11 In reply to 2990.10
I'm not sure if I've explained it well, I meant at the rightmost side...
Marc
2990.12 In reply to 2990.11
Hi Marc, I see - that makes more sense.
But I already have something else planned for that spot - some things will likely get a arrow there (similar to the one Styles header part, but only showing up when the mouse is on that item's line) that will open up a menu with some additional actions and stuff related to that particular slot.
Show messages: All  1-5  6-12
