Change the color of all styles by a script
All  1-2  3-6
A cool site for have some assorted colors from A photo ;)
http://www.degraeve.com/color-palette/
2987.4 In reply to 2987.2
thanks michael. your script is really nice. it works great. just another question. i need a shortcut for "adding a new style"and "edit style". can you help me again please?
thanks in advance.
crydee
2987.5 In reply to 2987.4
Hi crydee, yup it's possible to set those up.
To set up a shortcut for "Add new style", use this as the command:
script: /* Open Add new style dialog */ var gd = moi.geometryDatabase; gd.styleEditorOpened(); var dialog = moi.ui.createDialog( 'EditStyleDialog.htm?titleid=Add style dialog title&index=-1', '', moi.ui.mainWindow ); if ( dialog.window.doModal() != -1 ) { var styles = gd.getObjectStyles(); if ( styles.length > 0 ) moi.ui.propertiesPanel.editStyleIndex( styles.length - 1 ); } gd.styleEditorClosed();
To set up a shortcut for the "Edit styles" dialog, use this as the command:
script: /* Open Edit styles dialog */ var dialog = moi.ui.createDialog( 'EditStylesDialog.htm', 'resizeable,defaultWidth:380,defaultHeight:420', moi.ui.mainWindow ); dialog.window.doModal();
Hopefully that will get you wrangling your styles quickly... :)
2987.6 In reply to 2987.5
ah perfect. thats support. the bigger companies should take a close look to your response time. it's unique.
thumbs up.
have a nice weekend.
cheers crydee
Show messages: All  1-2  3-6
