Merge Lines?
2978.1
Hello,
I am having trouble merging lines together. I have three segments in a straight line that I want to merge into a single line. I type in the merge command and the segments stay the same. Does that command work on lines? Thanks.
2978.2 In reply to 2978.1
RebuildCurve. Type number of points for resolution. Check delete original when done.
The Merge is for those "Drill Down" edges on a surface that are not whole. So it you trim a surface, then drill down to its edge to use for "Blend" or something, and you see it is in 2 parts, you can merge that back to a single edge. It doesnt work for "seam edges".
2978.3 In reply to 2978.2
Of course if they are "straight line segments", join is there too.
2978.4 In reply to 2978.1
Hi OSTexo, currently merge only works on edges of a solid, not on individual curve objects quite yet. I do want to make it do that in the future though. There are a few things involving merging smooth segments together that need to be figured out first though, like should any kind of smooth segments be merged together, or should things like lines with tangent arcs touching them remain separate.
Currently the easiest way for you to merge those lines is to use Join to join them together as a multi-segment curve, then select it and use Edit/Show pts to turn on edit points and then select the internal points and delete them.
2978.5 In reply to 2978.4
Hello,
Thank you both for the assistance. I will try it out.
