Out of MoI Topic : VRML
2973.1
Hi All...
I have a problem export - import file using VRML ( *.wrl ).
My customer need VRML as their CAD communication data format.
The problem is when I export my assembly and its structure parts to VRML, all the filename / object is not recognize by another CAD program. Is this normal behaviour ?
Can VRML format bring the object name ?
I need your help ?
Thanks !
2973.2 In reply to 2973.1
Hi Anis, according to
http://accad.osu.edu/~pgerstma/class/vnv/resources/info/AnnotatedVrmlRef/ch2-23.htm
quote:
2.3.3 Node statement syntax
A node statement consists of an optional name for the node followed by the node's type and then the body of the node. A node is given a name using the keyword DEF followed by the name of the node.
So it sounds to me like there is a mechanism available in VRML for providing names for things, but it is optional. Probably whatever you are using for converting it does not try to put in the names.
VRML is a kind of an obsolete file format these days... It may be awkward to be able to find good tools to use it.
2973.3 In reply to 2973.2
Hi Michael...
I have double check the VRML file and yes, its contains DEF.
The problem is today most VRML cant read the DEF data.
Do you know VRML Viewer that can solve this case ?
Thanks Michael.... :) !
2973.4 In reply to 2973.3
Hi Anis,
Not that I know of... But I don't really know much about VRML viewers.
