Problem with flipped surfaces
All  1-6  7-13
2970.7 In reply to 2970.6
> Well, from your screenshot it looked like there were
> some different flipped parts along the hull. When things
> are joined they should all get a consistent direction, so
> it seemed like some of those parts were possibly not
> joined with one another?
I checked my model and I do believe you are correct Michael (should I have doubted it?). There appears to be some face wierdness going on as I think I have some faces sitting directly on top of each other. I rebuilt some curves and may have created some duplicates at that stage. I also thought my model was fully joined but I don't think it is. It was... some time before I booleaned the torpedo belt to the hull.
I'll go back to the hull without torpedo belt and see what I get.
Mark
2970.8 In reply to 2970.7
Hi Mark,
Just to add to this and help you find out if your model is joined and to find open/unattached edges, there is a script to highlight these 'naked' edges that you can assign a keyboard shortcut to.
script:var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
(Note:the script is one long line)
[EDIT]:BTW this only works for V2.
2970.9 In reply to 2970.8
I see a couple of "brians" moments in this thread.
Brian
2970.10 In reply to 2970.9
>>>I see a couple of "brians" moments in this thread.>>>
I see that also!
A user of "Beta" software had some issues with his model and entered the forum with a question. Received Prompt response to his question along with some tips on what he may have possibly done with his model that could help to avoid this in the future (The learning) and accompanied with a few more posts of very usefull information for the user to continue his wonderful MoI experience! :O
Just about "Identical"! :)
2970.11 In reply to 2970.10
Thanks so much for the script Danny. This one is a definite keeper. I ran it on the pre-booleaned version of my hull (definitely successfully joined) and it found a missing (very tiny) surface. Brilliant!
Regarding the "Brians" moments, this is one of a small handful of forums I visit where there really are no stupid questions. I make a point of using the search and more often than not I find a post that gives a solution to a question I was about to ask. When I can't, there are great responses like these.
Thanks to all!
Mark
2970.12 In reply to 2970.11
A couple of quick renders of the "fixed" model. Detailing to come...
Thanks again for the help guys.
Mark
2970.13 In reply to 2970.12
Looking very nice already Mark!
Show messages: All  1-6  7-13
