Sweep doesn't turn 90deg
All  1-13  14-15
297.14 In reply to 297.13
> I think I understand your method but will try later today to see it for myself.
Sounds good, please let me know if it doesn't seem to work right.
> I can imagine that the double surfaces were created in the modelling
> process as sometimes I did not understand exactly what happened
> during a trim or boolean.
I think that something may be duplicating things in an unexpected way. Anyway, if you happen to notice this happening during a modeling session, please let me know.
> I added two renders of objects created with MoI, rendered with C4D 6+.
Looks groovy! :)
297.15 In reply to 297.11
Other than that, it looks like you may be running into a problem where the boolean operations don't quite work as expected right now when one of the objects involved is an open surface instead of a closed solid.
Yes, I can confirm this. I was trying to make a threaded screw. I swept a circle along a spiral curve, then tried to subtract it from a cylinder. But, when I tried to do the boolean, it didnt work. I looked at the ends of my sweep, and they where open. I selected the ends and closed them with 'planar'..then the boolean worked perfectly.
Show messages: All  1-13  14-15
