missed faces
All  1-15  16-17
2968.16
...hmm, the problem is not the file size. (I also use the V2 Beta Oct-19-2009, Vista 64 bit)
After creating your geometry/figur with curves, you have to "Join" the curves and then you can use "Planar". ;-)
2968.17 In reply to 2968.13
Hi andras,
> Hello michael I found a similar issue in the new beta
> (October) version.
> I used planar command . If I scale the object the problem
> is not existing.
Yeah, this is the same issue as before - the line that does not behave well there is very tiny in size, only 0.001 units long.
I just do not currently recommend making objects that have any individual features at such a small size (especially approaching close to 0.001 units), you will likely continue to run into this problem many more times with trying to create objects at that small scale right now.
I have adjusted the Planar command for the next beta so that it will work properly for this now though.
Show messages: All  1-15  16-17
