What creates apparent size in the final output?
2955.1
Hi, there,
I realize this is probably not a MOI question, but I don't have any other software that I use, nor do I trust other forums to the extent that I do this one for non-biased advice. :)
What is it that makes the final model (render?) look big or small? For instance, I've seen whole buildings (modeled, of course) that seem as small as a foot or two high, and others that seem, well, like a real building "should".
So my question is, what do you have to do to get your final result to look the same relative size as what you're modeling? Is it a function of the model, one of the rendering, or is it post-processing like in Photoshop?
Thanks a lot, and sorry if this is obvious,
- Paul
(AngelicLight)
2955.2 In reply to 2955.1
Hi Paul - well when you create a rendering, there is a kind of "virtual camera" that you can position wherever you want and the image is generated as if it was looking through that camera.
To make something look like a familiar size it would mostly involve placing that virtual camera to a relative location to the object that human eyeballs would most usually see it.
So for example don't place the camera 100,000 meters above the building, stuff like that.
EDITED: 12 Mar 2010 by EDDYF
2955.4 In reply to 2955.3
Thanks very much to both of you. This makes sense now.
