How to join the trimed edges?
All  1-2  3-15
2953.3 In reply to 2953.1
Maybe a bug? (not it is after seen the Michael message :)
So Select all
Separate all
Select all
Boolean union
2953.4 In reply to 2953.3
Hi Pilou, yup your method will work for that particular case because there is a kind of special simplification process that happens for planar surfaces in boolean union.
But I don't think that method will work for other things that are not only made up of planes.
2953.5 In reply to 2953.2
Thanks Michael, I just use the shortcut rightnow, I'm a ID student, use Rhino before and a friend introduce me the MOI, and I find it is enough to use and easy to DIY.
I like it very much, and this is the just problerm I meet---- thanks --
2953.6 In reply to 2953.2
Hello Michael,thanks to Solut my problerm, I've tried all the command in MOI before you tell me, and after that I was looking for the new command,
2953.7
Hi Michael G.,
Where is the new Merge command?
Michael Tuttle a.k.a. mictu
http://www.coroflot.com/fish317537
2953.8 In reply to 2953.7
Either Make a keyboard shortcut, with Merge as the commend, or just type Tab+Merge. No GUI. It's in the commands folder. V2 Beta.
2953.9 In reply to 2953.7
Hi Michael T, yeah Burr's got it covered above - I have not found a place to put a button for it yet so you need to set up a keyboard shortcut for it to run it now (or type in the command name).
2953.10 In reply to 2953.9
Thanks Burr & Michael G.! That's pretty cool and very useful!
Michael T.
2953.11 In reply to 2953.9
Hi Michael G,
> I have not found a place to put a button for it.....
Just curious, but have you restricted the tool palettes, by design, to three rows, can't you add a 4th ?
There is on more spot on the Edit palette, can't you use that spot, maybe shuffling some of the icons though.
2953.12 In reply to 2953.11
Hi Danny,
Well, I've just got a general hesitation to add new icons in to heavily used areas.
When areas become dense with many icons it tends to make it more difficult to browse the UI and find the particular thing you are looking for.
So there's a pretty high bar to adding in a kind of "top-level" icon into a high traffic area.
One thing I'm particularly worried with Merge is having it too easily confused/crossed with Join.
I think that sometime in v3 I will be trying to have a kind of "advanced tools" menu where I can stash a bunch of things that are not really needed too often.
2953.13 In reply to 2953.12
Thanks Michael G, I love the MOI very much, the sketch line is powerful,The shell tool, the Boolean tool every tools seems very clever to do every order.
I see the script used JS,Html,Xml,,It's amazing,,,,,I used Maya Mel before,and I find it's as powerful as it.
I like it and thanks MOIer.more peple will use moi.
2953.14 In reply to 2953.12
I've added a Merge to my shotcut,but it shows jscript error,,,
EDITED: 29 Sep 2009 by QIBENTIE
2953.15 In reply to 2953.14
Hi qibentie,
Which version of MoI are you using?
The merge command is only available in the current v2 beta, it doesn't work in MoI v1.
Show messages: All  1-2  3-15
