Exporting objects from Moi to 3DS Max is a disaster when rendering..
All  1-5  6-8
2948.6
Also 3ds Max 2010 has SAT data translator, see demo video here http://www.autodesk.com/us/3dsmaxdesign/connection_extension/sat/3ds_max_design_extension_sat_820x510.html
does anyone know if it works with MoI .SAT files. Please let us know.
EDITED: 28 Sep 2009 by NEO
2948.7
Hi Rick, you may want to check this thread:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2766.1
2948.8 In reply to 2948.7
Yup, the thread bisenberger shows above is good to reference as well.
That's another difference that I forgot to mention between MoI and Rhino's OBJ export - MoI can export n-gons (polygons with more than 3 or 4 sides), while Rhino only exports polygons that have a 3 or 4 sides.
Some programs or import plug-ins can have difficulty dealing with complex n-gons.
When you export from MoI there is an Output: option that you can switch between Output: N-gons, Output: Quads & Triangles, and Output: Triangles only.
So if you want to have an output the same as Rhino you would set that to Output: Quads & Triangles.
However, it is pretty nice to have N-gons if possible as it makes for a cleaner looking wireframe in your modeling views. Using FBX format with the latest import plugin helps to get both n-gons and shading normals transferred over into Max properly.
Show messages: All  1-5  6-8
