List of objects ?
 1-19  20-24
2944.20 In reply to 2944.17
< for good measure
Yep, for this time my 2D prog make the same and permit 2 same names
so the workflow can be as soon an object is created select it on see if the counter up side right page is increased ;)
PS Blender don't allow to give a same name for 2 different objects of same nature ;)
2944.21 In reply to 2944.19
I personally prefer the second one.
Regarding the styles I will prefer a double click on the styles name for edit (and delete) and a "plus" button instead of the arrow for add new style.
In any case thanks for the time spent in this improvements.
Luca
2944.22 In reply to 2944.21
Hi Luca,
I've generally tried to stay away from double clicking.
In the next v2 beta there are some new shortcuts for editing styles - in the browser if you Ctrl+click on a swatch, it will pop up a color picker and let you change the Style's color quickly.
Also in the Properties Panel (in the upper-right area where you set the object name), if you right-click on the style line it will pop up the "Edit style" dialog that lets you edit the name and color of a style.
Also in the "Edit styles" dialog, if you right-click on a style it will pop up the "Edit style" dialog immediately (shortcut for pushing the Edit button on that dialog).
That would not be a good fit because there is more stuff on that menu than just "add new style" - currently there is another entry there for "Edit styles" and probably in the future there will be additional stuff there.
If it was just a plus button, that would too strongly suggest only adding and not any other kinds of style related tools.
Additionally a plus sign there could possibly get confused with the Collapse/Expand mechanism where you can click on the header parts of the scene browser to collapse or expand that section.
2944.23 In reply to 2944.20
I tried it, and it doesn't seem to give any pop-up warning like you were talking about though, it just seems to automatically change one of the names with a 001 added to it?
Anyway, still seems to be quite a bit in the minority...
2944.24 In reply to 2944.23
yes it's automatic as soon as a new object is created so no need to warn ;
Blender is a nighmare!
http://wiki.blender.org/index.php?title=Doc:Manual/Modelling/Objects/Groups_and_Parenting&oldid=74301
Show messages:  1-19  20-24
