List of objects ?
 1-12  13-24
2944.13
Micheal, I agree.
Pilou, maybe you could save a "version" before you make major changes:
The first is my favorite (thousands of users worldwide)
(Sub) Version Control - Open Source
Tortoise SVN:
http://tortoisesvn.net/about
http://tortoisesvn.tigris.org/
Free Document Management Software
M-Files Express:
http://www.m-files.com/fra/express_free.asp
File Hamster: Real-time backup & File Revisions ~ $ 29
http://www.filehamster.com/
- Ralf
2944.14 In reply to 2944.12
In fact generally as you can't create different objects with the same name, you can't erase 2 objects with the same name :)
Anim8or ;) http://www.anim8or.com/
Maybe it's not exactly a normal CAD program ;)
So I will see with attention the right up corner and I find it's to hard for me I will ask a special flashing text :)
@Ralph : yes I can make also this : a little copy before delete action
EDITED: 28 Sep 2009 by PILOU
2944.15
@ Pilou
Hmm, there is a difference: A version is a version and many versions are a file history of versions -> starting from the first version of the same file ;-)
2944.16 In reply to 2944.14
But that does not seem to be the case - it seems to be more common in other programs to allow naming more than one object with the same name.
Like I mentioned before, I tried Rhino, ViaCAD, Cinema4D, and Silo, and every one of these programs do not pop up a warning or prohibit assigning the same name to 2 different objects.
That is interesting that Anim8or does not allow it, but that seems to be in the minority...
2944.17 In reply to 2944.14
Hi Pilou, for good measure I tried a couple of additional programs, this time some 2D ones: Creature House Expression and Paint Shop Pro.
These programs also have the ability to assign names to objects and once again there is no restriction that prevents 2 objects from having the same name.
2944.18 In reply to 2944.17
What about have the object list (and the blank space) in the "edit object name" window?
So if I want to add parts to an existing object I just select it from the list, if I want to make a new object I can see if it's already there. I know that for very complex project we can have a lot of objects, but for me is better than nothing.
2944.19 In reply to 2944.18
Hi Luca, I've thought some about possibly having a dropdown arrow on the Edit object name dialog, to help to pick an existing name.
But there may be a different way that could be better. I've thought some about having an additional button on the line for a named object in the object browser, that would allow you to assign other objects to that same name.
One possibility would be a small + button that was in between where the Status/Eye label is and the name.
That would then be similar to how you can click on a Style's swatch in the browser to assign the selected objects to that style.
The other possibility might be instead of having a + button there could be an arrow on the far right side that would pop up a menu with some choices on it, including "Assign to this name".
2944.20 In reply to 2944.17
< for good measure
Yep, for this time my 2D prog make the same and permit 2 same names
so the workflow can be as soon an object is created select it on see if the counter up side right page is increased ;)
PS Blender don't allow to give a same name for 2 different objects of same nature ;)
2944.21 In reply to 2944.19
I personally prefer the second one.
Regarding the styles I will prefer a double click on the styles name for edit (and delete) and a "plus" button instead of the arrow for add new style.
In any case thanks for the time spent in this improvements.
Luca
2944.22 In reply to 2944.21
Hi Luca,
I've generally tried to stay away from double clicking.
In the next v2 beta there are some new shortcuts for editing styles - in the browser if you Ctrl+click on a swatch, it will pop up a color picker and let you change the Style's color quickly.
Also in the Properties Panel (in the upper-right area where you set the object name), if you right-click on the style line it will pop up the "Edit style" dialog that lets you edit the name and color of a style.
Also in the "Edit styles" dialog, if you right-click on a style it will pop up the "Edit style" dialog immediately (shortcut for pushing the Edit button on that dialog).
That would not be a good fit because there is more stuff on that menu than just "add new style" - currently there is another entry there for "Edit styles" and probably in the future there will be additional stuff there.
If it was just a plus button, that would too strongly suggest only adding and not any other kinds of style related tools.
Additionally a plus sign there could possibly get confused with the Collapse/Expand mechanism where you can click on the header parts of the scene browser to collapse or expand that section.
2944.23 In reply to 2944.20
I tried it, and it doesn't seem to give any pop-up warning like you were talking about though, it just seems to automatically change one of the names with a 001 added to it?
Anyway, still seems to be quite a bit in the minority...
2944.24 In reply to 2944.23
yes it's automatic as soon as a new object is created so no need to warn ;
Blender is a nighmare!
http://wiki.blender.org/index.php?title=Doc:Manual/Modelling/Objects/Groups_and_Parenting&oldid=74301
Show messages:  1-12  13-24
