Curve text
 1-12  13-32  33-48
2920.33 In reply to 2920.29
>You need to change those to point to your icon file when you want to replace those ones.
I did that, replacing them with my own custom icons But as I said is a bit long to do every time with every Beta :(
Perhaps you could consider designing some like the rest of them (I really like your style)
2920.34 In reply to 2920.33
Hi neo,
Unfortunately doing icons is really quite finicky and time consuming work - I'm pretty happy when I get a chance to use some predefined ones.
So it's not likely that I will get a chance to do new ones for those anytime soon.
One thing that I did update though is how the icons are loaded for these special res:// cases .
In the next v2 beta, when there is a res:// icon it will first check to see if there is a PNG icon of that same name in the \ui\icons subfolder, and if it is it will load that file rather than get it from the built-in resources.
So that means in the next v2 beta you will be able to override those icons by just dropping new ones in \ui\icons and you do not need to alter the HTML.
For example to override the File icon which in the HTML is specified as res://FILEICON you can create a file at \ui\icon\FileIcon.png and it will use that one.
One note - the icon for Edit/Copy that was previously res://COPYICON has now been changed to res://COPYCLIPBOARDICON to avoid the collision with the existing CopyIcon.png which is the Transform/Copy icon.
So in the next v2 beta the icons that you can provide to override the resource ones are:
2920.35 In reply to 2920.34
THANK YOU MICHAEL
2920.36
That's a cool update, Michael, and I don't even bother with the icons! :-P
-Will
2920.37 In reply to 2920.32
Hi Burr & Michael...
Finally I got this :
2920.38 In reply to 2920.37
There you go Anis. Nice Job! Next you'll make a backup copy of your MoI.css file and start changing colors around there! :O
2920.39 In reply to 2920.38
Hi Burr....
Are you working on modify moi.css for us ? :)
When it will realease.....
Cant wait for it...
Thanks !
2920.40 In reply to 2920.39
Hi Anis,
Then you can start to get stuff like this:
But I probably wouldnt be doing anything like this with MoI. I'm not very artistic and wouldnt make much of a UI designer. After the release, I'm sure a few will pop up though.... Pilou has an eye for these things and used to change his "daily"! There were a couple others like Ash that were pretty good at this... I'de wait for them to chime in when all is said and done...
While the betas are changing so often, it really is a waste to invest any amount of time in it, as things can change from one month to the next and you cant expect that all your work will just "migrate", so we'll just wait for the release.
2920.41 In reply to 2920.40
< Pilou has an eye for these things and used to change his "daily"!
oh no It's not me! I change just Option French / English!
I prefer original ! it's Zen! And I want peaceful quiet image!
Because I have yet this all the day! :)
2920.42 In reply to 2920.41
I guess I just remember this stuff changing daily!
2920.43 In reply to 2920.42
Ah yes!
It's different ;)
It's just Copy screen inside 2D prog for publishing! ;)
It's not new UI :)
2920.44 In reply to 2920.16
Hi Burr,
Thanks for filling me in on the source of the color icons. I kind of like them. I did try the custom UI's during MOI's version 1.0 phase, but I found I'm not very adventurous when it comes to customizing the look of MOI. I think the simplicity of the UI is one of the things that makes it so good.
Jesse
2920.45 In reply to 2920.44
Hi Jesse,
I agree. I seem to make it worse! I think some like to make it look like their other apps. I dont already have a preference though. I liked Lyes' icons and kept them though.
It seems that Lyes has left the forum? Too bad. His helmet modeling video was a real awakener for me!
2920.46
What is/are the best way/s to write something around the lateral surface of a cylinder?
2920.47 In reply to 2920.46
2920.48 In reply to 2920.47
I had tried flow command and it did not provide my desired effect first that is why I asked :)
Tanx to your hint, I realized that I had made a mistake and by rectifying that mistake I was able to use flow command to get to my desired effect.
Tanx :)
Show messages:  1-12  13-32  33-48
