Blend for a friend
All  1-5  6-10
2915.6 In reply to 2915.3
Hi Danny, here is an example of the kind of thing that does not tend to work very well if the blend is specified as having a kind of absolute width for it rather than being based off of a scale factor applied to the distance between 2 matching points:
2915.7 In reply to 2915.4
> I think I would be more likely to try to have
> an option to separate out the bulge into 2
> sliders so that the bulge of each side could
> be manipulated independently
Yes, that would nice, I just felt sometimes we needed that little bit of extra control in the shape of a blend.
Are you going to try this out to see if it fits or will it be a future thing, either way it would be good to have ?
Thanks for looking into this!
"Hi Danny, I definitely want to improve Blend in the future but the currently the main goal for it is to be able to handle a string of edges on either side rather than just 1 edge on each side."
That would be great. The more I use MoI, the more I realize "blend is your friend". It makes easy work of a lot of situations, and any enhancements would be welcomed. I assume if blend could handle multiple edges then it could be used like a patch?
As great as all the UI and organization enhancements have been, I look most forward to enhancements like this in the basic modeling functions.
Ed
2915.9 In reply to 2915.7
Hi Danny,
It's an idea for the future - I'm not going to be able to get that in for v2.
2915.10 In reply to 2915.8
Hi Ed,
Well, not really because it will still be something that is a connection between 2 different sides, just that each side would possibly be a chain of several edges touching end to end.
Patch is different and instead of taking "2 sides", it takes a closed loop of curves/edges.
You can kind of think of Blend as being more like a 2-rail sweep, just with the profile curves being created for you automatically.
Show messages: All  1-5  6-10
