About locked objects
All  1-4  5-8
2900.5 In reply to 2900.4
> About the transparency : if you display the object one
> frame by two at more 20 ps by second
> you will obtain for the eye 50% of transparency
> without touch the render!
That would tend to make more of a flickering appearance rather than a really proper transparent looking one.
The other problem with that would be a requirement to be constantly re-rendering the entire scene at all moments even if nothing had changed, that would cause things like MoI to consume a lot of CPU time even when it was just sitting there.
Currently MoI only redraws the scene when something has changed and the display needs to be updated to reflect the change. If you just sit there and do nothing, the display does not need to be redrawn which is good because it does not take up any CPU/GPU resources right then.
> About the collision it's not "physic engine"
> just have possibility to modify a cube inside a sphere locked ;)
Instead of locking, it is better to instead use hiding for a sphere that is getting in the way.
If you hide the sphere that is getting in the way then you can much more easily work on modifying the cube inside of it.
> Seems yet possible?
Yes, there are other ways to select the "inside cube" - you can do a window select, "select all", or use the scene browser for example.
But really the best way is to hide things that are getting in your way, rather than locking for that case.
If you need to hide and show the same object repeatedly, it is a good idea to give it a name, then you can use the scene browser to target it easily with one click in the "Objects" section.
At some point in the future I may be able add something like making locking have a transparency effect, but like I mentioned it will take some time before there is a proper working transparency mechanism.
2900.6 In reply to 2900.5
Yes transparency locked object seems the best when you want to see the internal object in the same time for modify it without modify the visible sphere by error ;)
Or simply for draw a new object inside the locked sphere à the good place!
No cursor of transparency for the normal Edit color Object?
EDITED: 5 Sep 2009 by PILOU
2900.7 In reply to 2900.6
Yes, transparency for locked objects would be good for that particular situation.
But until then you can get the equivalent of 100% transparency just by hiding the object that is on the outside and in the way.
That will let you get this job done currently.
> à the good place!
Actually though for other drawing tasks having locked objects be transparent and also automatically not targeted by the mouse at all could be bad, for example what if you wanted to draw the new sphere snapped on to some particular point of the box?
If the box was transparent and also totally ignored for all kinds of mouse interaction, it would then not make it possible to use as a reference guide object which is currently one of the main goals for locked objects.
So even in the future when there is transparency available, there will still probably be a second setting for "snap to locked objects", which you would also enable or disable separately, so that you can use the objects as a snapping guide.
Sorry I'm not sure if I understand this question.
Do you mean being able to make an object transparent by editing properties of its style? I would also like to make that possible in the future, but that won't happen for v2 because like I mentioned it will take some additional work to make transparency possible.
2900.8 In reply to 2900.7
< Do you mean being able to make an object transparent by editing properties of its style?
yes :)
Show messages: All  1-4  5-8
