August 8 beta always asks for license key on Vista if not run as administrator
All  1  2-4
2860.2 In reply to 2860.1
Hi Crusoe, I cannot seem to repeat this problem running on a Vista 32-bit system over here...
Could you please give me some more information about your Vista system? Like is it 32-bit or 64-bit?
Have you possibly set up some custom restrictions for the login account? If access to the "AppData" folder has been denied for that account (which I think would only be the case if you had set up some customized permissions), then it could produce that kind of a problem with prompting you for the license key again and again.
One way that you can solve it is to create a text file that has your license key in it on the first line of the file, name the file "moi_v1_license.key", and place it in the same folder as moi.exe and then it should be able to find your license key when you start it up.
2860.3 In reply to 2860.2
UAC can interfere also.
2860.4 In reply to 2860.1
I'm running Aug 8 beta on Vista 64 not as an administrator with no problems.
- Dave Morrill
Show messages: All  1  2-4
