Hi Petr, that's great that you can get your 2-letter shortcuts to work now, I was hoping that the new keyboard options would let you get set up for that better.
Maybe in the future I can get some more built-in 2-letter support where you would not have to hit space/enter at the end, but it is a bit tricky.
>> Updated SAT export - closed surfaces are now split into
>> 2 joined half pieces
> It won't apply in case of writing the analytic surface (i.e. moi.ini
> WriteAnalyticSurfaces=y), will it?
Actually it still does apply even then - writing analytic surfaces does not do anything for SAT export, analytic entities are not supported for SAT format export in the I/O library currently. That may happen at some point but not likely anytime soon.
> There is still no command prompt for Show pts command
> when running command without preselection like I mentioned
> many months ago...
Oops, looks like I forgot to write that one down previously, I'll see about fixing that up.
> and I think the options dialog window section "View" needs
> sorting a bit (Import/Export section sets a good example). It
> looks quite chaotic after you added a couple of new (more or
> less related) buttons and checkboxes in a reckless manner ;)
I've done a tune-up for the next release - I made a new "Colors" section that contains Background color, Surface color, Edge color, and "Locked objects use alternate color" within it. Then the remaining stuff is underneath it more or less the same as in the current beta. That seems to help.
