command for view reset?
All  1  2-8
2838.2 In reply to 2838.1
Hi okapi, put in the following for the keyboard shortcut:
script:moi.view.resetAll();
Then if you hit that key once, it will frame the selected objects, and if you hit it a second time in a row, it will switch to frame all objects.
EDITED: 6 Aug 2009 by MICHAEL GIBSON
2838.3 In reply to 2838.1
Hi Okapi,
Try this page : http://kyticka.webzdarma.cz/3d/moi/
2838.4
Thanks Michael and Anis.
Anis,
thanks for pointing that out, I had forgotten about the amount of scripts already documented there!
2838.5 In reply to 2838.4
Hi Okapi,
Yup, Bank of MoI Script :)
BTW what kind of project do you design with MoI.
-Anis
2838.6 In reply to 2838.5
Hi Anis,
this is what we do: www.moka-studio.com
2838.7 In reply to 2838.6
Hi Okapi...
Looks like you are an architect with many good project there.
What is your workflow when create 3D model - Rendering ?
In which area MoI participate in your project ?
Would you like to share some "original" project screenshot from MoI ?
Success for you !!!
2838.8 In reply to 2838.7
Hi Anis,
thanks.
yes I am an architect -
We (the studio) do visual work, so the projects on our website are not our own designs (for the most part).
Other than moi we also use modo / rhino / cinema4d to model.
modo / ar / Final Render to render.
I personally like to model with moi, as I really like the workflow.
We also receive a lot of models from our clients, especially on larger /more complex projects (where the design is often done in 3d).
A lot of these are 3dm models, so it is good to have moi to export.
Mainly I have use moi to do Ngon exports thus far, and to model detailed elements.
However with the latest beta I now think I will be using moi more for complete modeling, when I do the modeling.
I will see to post some samples of meshes done in moi when I get a chance,
Show messages: All  1  2-8
