New beta or release ?
All  1-13  14-17
283.14 In reply to 283.12
> Hi Michael. How about displaying the feedback line smack in
> the middle of the current viewport (a simple white text in black
> frame should be visible against any viewport color scheme).
> Then when you click the cursor into an input field (or in current
> viewport), the feedback line will disappear...
Well, the thing is that it would be nice to use some text feedback not just for error messages, but also for some general information. Like when you do a window select if there was a feedback area I could print out the number of objects that were selected by that action.
Text in the middle of the viewport would probably get annoying if it was displayed too frequently.
That's not a bad idea for only error messages though.
283.15 In reply to 283.13
> You mentioned you were going to collapse all the snapping options
> into a single menu, yes? There'd be all the more space then.
Yeah, but I was only talking about the little pop-up menus and different options dialogs. If you move your mouse to the "Grid Snap", "Straight Snap", or "Object Snap" buttons, there is a little menu that pops out above them, each of which has their own option dialog.
So that options consolidation won't change anything that is currently visible at the top level. It should just make it easier to get at all the options which are currently scattered around a bit.
283.16 In reply to 283.15
Understood, yeah, I use the object snap pop-up a lot.
Oh, and best of luck getting Fillet & everything worked out.
283.17 In reply to 283.16
Hmmm, I suppose it might be a good idea for me to leave that one in place in addition to having it available on the full settings dialog.
Show messages: All  1-13  14-17
