TRIM and EXTEND and other problem
All  1-3  4-7
2806.4 In reply to 2806.1
Hi Alessandro, it's a problem with IE8 and MoI v1.0 - due to a change in behavior in IE8 there is a side effect that the "Done" and "Cancel" buttons in MoI commands do not show up.
So probably a few days ago you installed IE8 and that is what caused this problem.
But you can install the v1.1 update for MoI to fix the problem, you can download that from here:
http://moi3d.com/1.0/update/moi_v1_1_update.exe
After you run that update installer, it should patch your MoI 1.0 installation to be version 1.1 instead which will then work properly with IE8 installed.
Please let me know if you still have problems after installing the update.
2806.5 In reply to 2806.3
Hi inve,
> yep!
> the same problem on window xp sp3 and on notebook (vista sp2)
> program original (of course) like the OS
Installing the 1.1 update from here:
should fix it. Please let me know if you still see the problem after updating.
2806.6 In reply to 2806.5
oh boy! still work perfect on notebook with vista!!! great!!!when i go home test it on win xp.
just a little think.
this update/fix is very importat, maybe you must put it on the site.
anyway thank's again.
Alessandro from italy.
2806.7 In reply to 2806.6
Hi Alessandro, that's great news, I'm glad it fixed the problem for you!
Actually, it is there - on the main MoI page (http://moi3d.com) click the "Download" link to go to the downloads section, and it is listed here:
Show messages: All  1-3  4-7
