Hi Alessandro, it's a problem with IE8 and MoI v1.0 - due to a change in behavior in IE8 there is a side effect that the "Done" and "Cancel" buttons in MoI commands do not show up.
So probably a few days ago you installed IE8 and that is what caused this problem.
But you can install the v1.1 update for MoI to fix the problem, you can download that from here:
http://moi3d.com/1.0/update/moi_v1_1_update.exe
After you run that update installer, it should patch your MoI 1.0 installation to be version 1.1 instead which will then work properly with IE8 installed.
Please let me know if you still have problems after installing the update.
