New lighting model WIP
 1-15  …  96-115  116-135  136-138
2801.136 In reply to 2801.134
Exactly what I had in mind. Thank you very much, Michael.
Danny, I'm pretty sure these are simply display options, so the surfaces and edges are still being assigned styles as they normally would, but we can now override the color component of those styles when displaying the surfaces / edges.
EDITED: 1 Aug 2009 by VODKAMARTINI
2801.137
shadow shadow shadow sun path diagram :)
2801.138 In reply to 2801.135
Hi Danny,
> How will "Fixed color" work , can we still change colours of
> edges or surfaces if we want to, if we choose this option ?
It's like vodkamartini mentioned above - you can still assign things to have different styles the same as before, it just alters the display only so that the display will show your fixed color choice rather than showing the style color as it normally does.
Exports are not affected, so for example if you export to OBJ format styles will be used for the materials saved in the OBJ file same as currently.
> Are the "Fixed color" edges of a Red cube still style red ?
Yes, everything still maintains the same property values as before, it just purely overrides the display.
Show messages:  1-15  …  76-95  96-115  116-135  136-138
