[Request] Rect from center advanced
All  1-7  8-20
2783.8 In reply to 2783.7
and like that? Move a yellow point move all yellow points without deformation
But without an example image i am afraid that not fully understand the problem :)
EDITED: 17 Jul 2009 by PILOU
2783.9 In reply to 2783.8
The goal would be to very fast draw a rectangle around anything and then tweak the edges by moving middles points.
@Pilou C'est pas vraiment ça en faite.
Imagine pour chaque lettre ou chiffre sur ma montre je fait des boundings box (j'ai mes raisons :D)
Donc tu as ta lettre par exemple un "S" en vue de haut, tu trace très vite un rectangle englobant le "S" a la main sans même te snapper.
Au moment ou ton rectangle est tracé ben si t'a coché la case "tweak" juste avant de placer le coin, t'a 4 points qui apparaissent.
1 point au millieu de chaque edge du rectangle. Et en bougeant chacun de ses points en click+drag tu affine ta bounding box.
Bien sur une fois que t'a affiné tu peux plus revenir en arrière.
J'espère que t'a compris ce que je demandais :)
2783.10 In reply to 2783.9
Draw this rectangular bounding box the more quickly?
2783.11 In reply to 2783.10
Exactly! But I start from the letter not rotated.
Maybe a button to calculate the bounding box would be more appropriate.
Seems a plug can do that easily! But Problem is there is an infinities of bounding box possible!
So waiting Michael answer ;)
2783.13 In reply to 2783.12
Yeah that would be cool.
The awesome thing is that you can then use the intersection between the bounding box and the shape to move it, or align etc..
Bounding box for 2d shape is easy, there's only 1 possibilities. For 3d too I think.
In all 3d packages you can switch viewport to bounding box, so I think its easy math to do :D
2783.14 In reply to 2783.13
< Bounding box for 2d shape is easy, there's only 1 possibilities.
I am not sure ;)
It's the same "S"
2783.15 In reply to 2783.14
Yes I know, you may see the same S but its totally different curves for the software.
Bounding box must be used before rotation :)
2783.16 In reply to 2783.1
Hi DesuDeus,
> I like the Rect from center tool, its very cool but it lack something.
> You should have two snap points, the corner + the edge close to it.
> For example draw a circle that's not align on any grid, then try to
> draw the bounding box... yeah its impossible !
> You can do it with a mix of tools (lines) of course but its not very fast.
As Pilou and Paul mentioned, it is actually not impossible at all! Just use construction lines to get your circle framed, it only takes a couple of seconds.
Maybe it is not clear that a Construction line is actually a special helper object in MoI and not the same as just drawing in additional regular line objects that you then have to erase.
Construction lines are special helpers that you can create any time you are drawing, by holding down the mouse and dragging on a point instead of clicking on the point.
So for example in your case you describe here about drawing a box around a circle not grid aligned, that looks like this:
So as you can see there, definitely not impossible! :)
And that can be done quickly too, just a couple of seconds as you can see.
Note that you do not have to exit the command to create construction lines - when I'm talking about "construction lines" I don't mean drawing additional regular line objects in the scene, I mean using the special quick construction line helper tool that you can do by dragging instead of clicking on points.
2783.17 In reply to 2783.15
Hi DesuDeus, from some of your other comments it sounds like you want a general tool to frame any selection of objects.
Something like that would be a more specialized "BoundingBox" command and would not be part of the drawing tools.
For a bounding box command you would not pick any points at all, you would just select objects, run "BoundingBox" and have it generate the frame - that kind of "generation from selected objects" is a lot different than a drawing tool.
Probably for the next beta release I can make a plugin for you that will do that kind of frame creation.
2783.18 In reply to 2783.17
Look at my answer in the "line from center point" request, your answer about c-lines helped me.
Okey cool, but in your example you have a circle, you can use the quad of the circle to help you.
Show me with the "S" letter that Pilou showed, how do you do it fast?
A bounding box command would be perfect yes :) Even better if it works in 3d too :D
And also if it works with multiples objects, just like the scale/rotate gizmo that show up when you select objects.
Thanks again for the explanations.
2783.19 In reply to 2783.18
Hi DesuDeus,
Yes, but the reason that I had a circle there because your initial question in this thread was about a circle :)
You wrote:
quote:
For example draw a circle that's not align on any grid, then try to draw the bounding box... yeah its impossible !
You wouldn't really want to try and draw a rectangle manually around something like that with the Rect from center tool, you would want to have a command generate that for you.
> in 3d too :D And also if it works with multiples objects, just like the
Yes, it would be basically like making that scale/rotate edit frame but as an rectangle curve object if you had all planar shapes, or as a box if you had 3D objects.
I'll see about cooking up a special command for that for the next beta.
2783.20 In reply to 2783.19
I should buy you cookies and ship them at you ;)
Thanks for all !
Show messages: All  1-7  8-20
