[Request] Rect from center advanced
All  1-18  19-20
2783.19 In reply to 2783.18
Hi DesuDeus,
> Okey cool, but in your example you have a circle, you can
> use the quad of the circle to help you.
Yes, but the reason that I had a circle there because your initial question in this thread was about a circle :)
You wrote:
quote:
For example draw a circle that's not align on any grid, then try to draw the bounding box... yeah its impossible !
> Show me with the "S" letter that Pilou showed, how do you do it fast?
You wouldn't really want to try and draw a rectangle manually around something like that with the Rect from center tool, you would want to have a command generate that for you.
> A bounding box command would be perfect yes :) Even better if it works
> in 3d too :D And also if it works with multiples objects, just like the
> scale/rotate gizmo that show up when you select objects.
Yes, it would be basically like making that scale/rotate edit frame but as an rectangle curve object if you had all planar shapes, or as a box if you had 3D objects.
I'll see about cooking up a special command for that for the next beta.
2783.20 In reply to 2783.19
I should buy you cookies and ship them at you ;)
Thanks for all !
Show messages: All  1-18  19-20
