[Request] Line from Center point :)
 1  …  22-41  42-61  62-63
2782.62 In reply to 2782.61
Its fairly straight forward will. You can keep a folder in your my docs where you copy any scripts into before you copy them to your commands folder. In same folder a text doc where you type your shortcuts and command names/scripts.
New beta release....Copy folder to folder and copy text to ini shortcuts section. Takes about 30 seconds.
2782.63 In reply to 2782.61
Hi Will,
> I sort of shy away from scripts cause when I update
> the betas, they usually don't follow over so I try to avoid
> using what's not within the MoI base functionality.
Actually the ones that are completely contained inside of a keyboard shortcut (rather than having additional files involved) do carry over between beta releases.
That previous "keep construction lines" one that I mentioned is like that - because the entire script is contained in the keyboard shortcut, that script gets stored in your moi.ini file and unless you have moved the moi.ini file it it will stay in its regular central location and be found automatically by a new beta release.
It's when you have a more intensive "custom command" installed which may contain a larger script or also has accompanying UI files, that you need to copy stuff over between releases. That's when there are additional files involved to run the script, like if you download a .zip file with stuff in it.
> If I remember correctly, I believe you've even created a utility
> to help carry over stuff
Yes, for every v2 beta release shortly after the release I've posted a utility program that will copy any custom commands you had for v1 over to the new v2 beta.
But you don't actually need that for this particular case with the "Keep construction lines" script since it does not have additional files, the whole script is just stored in the keyboard shortcut itself.
Show messages:  1  2-21  22-41  42-61  62-63
