[Request] Line from Center point :)
 1-16  17-36  37-56  57-63
2782.17 In reply to 2782.16
The on the fly construction lines are a powerful feature of MoI that I haven't seen anywhere else. Have you patented that system Michael?
However, I also like to use permanent construction lines and use that script A LOT. It is very good and I had hoped that this would make it permanently into MoI V2 as you really need both systems. Luckily, nothing Michael has done for V2 broke it :-)
Tony
(aka HamSoles)
2782.18 In reply to 2782.17
Hi Tony,
No, it kind of tends to be a pain to get stuff patented, you have to hire a lawyer that's experienced in it and jump through several hoops.
Also the US Patent system is really a big mess when it comes to software patents, and it is frequently abused. I am happy to stay away from it as much as possible.
But yes, MoI's construction line system is unique as far as I know. There are several other systems that create guidelines on the fly, but every one that I have seen is similar to Ashlar-Vellum's original Drawing Assistant mechanism, where the lines radiate out from a single base point, rather than being more generally defined by 2 distinct points like MoI's construction lines are.
That's why the ones in MoI have so much additional functionality - stuff like the reflected endpoints as shown in the above screenshots, getting the midpoint between any 2 points, capturing a distance and using it elsewhere, etc... - much of that additional functionality is enabled because of having having 2 points defined for each guide line so that there is an actual distance associated with it and not just a location and direction only.
The other problem that tends to happen with the "Drawing Assistant" style lines is that they tend to trigger pretty easily and can quickly fill up your whole working area with snap zones, which is fine for simple mechanical drawings but really gets in the way if you are trying to do more subtle drawing with freeform curves and such. One other nice thing about MoI's system is that it stays out of your way until you want one.
> systems.
There are still a few unresolved UI issues about making an "official" permanent construction line mechanism, like should you be able to select construction lines somehow so you could remove a particular one? At the moment there is not any infrastructure in place for that part.
Also, in addition to that custom command, you can also set up some keyboard shortcuts to keep the clines you have created in the current command:
http://kyticka.webzdarma.cz/3d/moi/#KeepCLine
2782.19 In reply to 2782.18
Hi, Michael,
I know that getting a patent is both expensive and time consuming so I'm not surprised that you aren't getting involved with that :-)
I know what you mean about the 2 point guides - this is what annoys me most about CorelDraw, only one point (in the version I'm using anyway). Back in the late 80''s, early 90's I use an app called Illustrator II from a company called Intercap. Is was a dedicated technical illustration system and ran on Apollo workstations. It had a brilliant guidelines system, including 2 point lines, circles, etc. I still miss it sometimes.
Er - I can do this now in the latest beta - click on construction line, shows up as a default style, press delete. Click and drag construction line to move it. Just need a built in command to add a permanent construction line. Or am I missing something?
What doesn't happen is that the line gets highlighted and there is no access to the right click menu to rotate etc. Would be nice to have that too.
Tony
(aka HamSoles)
2782.20 In reply to 2782.19
Hi Tony,
Yeah, it's some of the stuff relating to feedback on selection like the glow for mouseover highlights, and showing it in a selected state that does not currently work.
Also some other things like window select, ...
It will take some work to iron out all the details.
It's also probably not that great that when you make them stick that they can be moved so easily, probably it would be better if it behaved more like a background bitmap and stayed locked in place unless you went to a special command or mode to adjust them.
2782.21 In reply to 2782.20
I like this feature as it is - I would much rather have a lock guides feature than having to go into a special mode just to quickly adjust a guide that I didn't get in quite the right place the first time. Much nicer work flow. Making them like a background bitmap is the opposite of what I would expect. Should work just the same as for objects, imagine if all objects were locked just after you added them, then you had to enter a different mode to edit them :-)
Also, all the other apps I use that have guides work that way. Full adjustment unless guides are locked. Most of them just have a global lock all guides, doesn't work on individual ones.
Tony
(aka HamSoles)
2782.22 In reply to 2782.21
Hi Tony,
Well, that tends to be another problem, getting "feature creep" with getting a whole bunch of extra icons and special modes, etc...
That's kind of the path to UI complexity that I'm trying pretty hard to avoid overall with MoI in general.
That's why I would probably make the "lock/unlock" be kind of implicit within the command similar to background bitmaps. The construction lines would be locked (they are generally meant to be more of a snapping guide than to behave as regular objects) after you exited the special "cline" command, and if you wanted to adjust them you would go into that command which would allow you to adjust them.
Anyway, that just shows that it is a pretty complex area that needs a lot of thought before making it a final feature... That's why it did not really come together yet for version 2.
2782.23 In reply to 2782.22
Okay, I'm going to argue now :-)
But is that not what you are suggesting with ...
and..
All I'm suggesting is to turn it around. One special command to lock all the guides. Manipulating guides works as now, but on persistent clines. Click, drag, right click get the wee menu. No extra icons required except for lock guides.
Just my tuppence worth ;-)
Tony
(aka HamSoles)
2782.24 In reply to 2782.23
Hi Tony,
> and..
Well not exactly - I'm suggesting that there could possibly be just _one_ additional icon for a "clines" command similar to the current plugin.
That would be the spot to go to draw in a bunch of persistent clines, and also to manage them.
From what I understood about what you were mentioning previously, you were asking about having a cline command similar to that current custom command, and also in addition to that a completely separate "lock clines" additional button... That's a 2 times increase in buttonage! ;)
Well, again that's some additional UI stuff to work out - what you are describing now is different than the custom cline command that we were talking about previously.
That's even another issue that needs to be worked out - should there be a special "cline" command that would let you draw in clines without needing to be within some other command to make them? (this is like that custom command)
Or should there be a "keep clines" button that would just let you keep the clines you have created inside the current command? That's rather different.
Again, a lot of UI issues to work out, definitely needs plenty of time to make this nice, that's why it was not particularly feasible to tackle in v2 yet.
2782.25
Interesting discussion!
I think it would be sorta nice to have a construction line entity so that you can place multiples.
Typically when I work on my drawings, I'll lay down some perspective lines on a locked layer to work off of - I could see having similar in MoI.
If you can figure out the UI Michael, I think it would be a nice feature to have.
Does this mean the individual CLines will have the same features as the dynamic one has now i.e. the little menu to reorient, relocate etc?
That would be cool for sure!
-Will
2782.26 In reply to 2782.25
Hi Will,
I don't know... That would be among the many issues to figure out.
But I guess I could see popping up the little menu launcher tag when you clicked on one to select it.
2782.27 In reply to 2782.26
Why dont using Inkscape type of guides? (its free, install it and try guides) Just for inspiration.
Its just like the guides in photoshop vertical or horizontal but it has a point somewhere on the line that you can drag to re-position
the line, also this point can be moved on the line (the point can be moved horizontally on an horizontal guide, vertically on a vertical one)
Why not making clines that work that way with a button in the ui...
1. Click on the cline button.
2. Click on a first point, then on a second point, an infinite line is drawn between the two.
optional 2.1 (to snap the two points, you could also use the current clines that are already in MoI (the help lines) to help you positioning the two points))
3. You can move these points at any time just like other points, the line is always straight.
4. But you can also move the two points at the same time, or the whole line to move it parrallels.
Basically it would be like click'n'drag like the actual help lines in MoI but it would create lines that stay, also it would be cool
to be able to change the color in the MoI options. And these lines would be auto-locked, to move it instead of click just click once on it to delock and show the 2 points, then click on points to move them or on the line to move it or select the two points and move, if you click or select any other things the line would just lock itself automatically.
Also using a shortcut that show/hide clines would be very cool, like the photoshop default one ctrl-h cmd-h.
2782.28 In reply to 2782.27
Hi DesuDeus, yes actually part of the discussion above is about having a cline command similar to what you are describing.
But the first priority for clines was to have something that was very quick to activate, that's why I did not want to rely on a separate icon off to the side of the viewport for their normal regular use.
With the current mechanism, the activation of a cline is very quickly available to you with a simple mouse gesture, you don't have to move all the way over to the edge of the screen to get one. That quick activation helps to make it easy to really quickly pop in a cline more seamlessly and fluidly while in the middle of drawing.
2782.29 In reply to 2782.27
Hi DesuDeus, also one other note on clines - it is actually possible in MoI to set up clines that stick around by setting up a plugin or using some keyboard shortcut scripts.
There is a plugin available here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1029.1
that will set up a custom command that lets you draw clines that stay until you clear them.
Also you can set up a keyboard shortcut with the script mentioned here:
which will let you set up a key that will keep the clines that you created during a command rather than letting them get erased as they normally do.
If you'd like some more flexibility with clines right now, you might want to set up one or both of those to get some additional functionality in the current version.
2782.30 In reply to 2782.24
Yes interesting discussion - this is what makes Micheal so cool - he listens and discusses features with his users!
Yes I agree, but I forgot this would be new as I already have one for the script - so it wasn't additional for me :-)
Yes you are right. I was.
YES. Absolutely, completely separate from the on-the-fly clines.
NO, this would be a nuisance. As Will said, it is good to lay down a few guides at the start (standard drawing technique). Would be a pain if you had to kick off a command just to get some construct lines.
To re-cap:
. new command to create a persistent cline.
. clines can be moved by dragging or deleted by pressing DEL - can do this today
. clines can be manipulated via the current cline menu - menu exists today but is not implemented for persistent clines
. persistent clines can be locked/unlocked - would need 2 new commands (lock and unlock), either shortcut or icon
So this looks like 3 new commands to be added to the UI. Could be reduced down to 2 icons, add cline and lock/unlock which could work same as hide/unhide.
I have no idea how much work it would be but, for V2, I would settle for a new command to create a persistent cline that has the little re-orient menu with no icon (I can add my own if I want as long as there is a command there). There's already ways to delete all the lines, move them and delete them.
Tony
(aka HamSoles)
2782.31 In reply to 2782.28
For Michael, (edit: not seen the previous 2 messages)
Yes I fully understand that, but before using the click'n'drag I was using simples lines and duplicates or move or mirror very fast.
And I still use them because I want permanent constructions lines that I can put in a style and show/hide them and lock them.
I already model pretty fast, modelling faster would create problems and errors from my side.
Instead of an Icon maybe a shortcut would do it? Like key+click
Or to get back to the original request (line from center) why not have a key to press while drawing a line to enable symettry, or a check box like make copy in the rotation tool? That would resolve many problems.
By the way keep the click'n'drag help lines they are cool, but I miss regular lines that are physically there and that react like normal lines.
If we look at the UI there's plenty of drawing tools that start from the center point, why not having a line? Its the less cluttered drop menu of all the 2d tools.
What im trying to say is that I worked for a long time without using the help lines in MoI but using traditionnal paper drawing techniques, all the people have different workflows for sure, what would be very different between help lines and lines from center point is that you would be able to change the angle and see the preview result in real time, for drafting or designing its very usefull.
Again im just a customer, MoI is already the best in his category and price range, Rhino is slow, T-splines are buggy, Maya nurbs are ugly like the maya interface, Catia is too much to pay as Alias studio as Solidworks. So even If I had money I'll go for MoI, I even use MoI instead of illustrator for doing techy drawings. Where I work a lot of people are impressed by MoI already :) But they dont do Nurbs :(
The whole problem is that MoI is already very stuffed, you can already do all the basic things and more complex things (still miss t-splines :P), its gonna be hard to keep the simplicity of the UI and the simplicity of the tools. But maybe in the futur if MoI have a liquid UI where you can drag'n'drop icons, people would make their own interface so having more and more tools will not be a real problem.
2782.32 In reply to 2782.30
Hi Tony,
Even 2 icons is a lot - that's pretty much a good example of the kind of thing that I would prefer to wait for a better overall design to try and squeeze it down to 1 icon instead.
Having the "lock/unlock" function be implicitly engaged while that command was running (similar to background bitmaps) would be one way to achieve that. Right now that seems to be the best candidate for compromise between flexibility and UI space, but maybe something different will be possible with more effort and focus on the design in the future.
Well, quite a lot to a good job designing the UI and various mechanisms to try and keep the overall program UI simple and not get bogged down with feature bloat...
UI design is one of the most difficult and time consuming things that I work on, really.
That's why this is good to discuss to get some ideas for future directions, but there is not really any hope to be able to actually finish this for v2 at all though.
2782.33 In reply to 2782.31
Hi DesuDeus,
Usually for something like that, there would be an icon for it, and you could optionally set up a keyboard shortcut for it if you wished.
You can actually set up a keyboard shortcut now for making persistent lines by installing this plugin which it sounds like you would be interested in:
> many problems.
Just because it is not necessary, since it is so quick to get the same result by using a construction line.
The construction line method is also a general purpose solution that works within any command, not just a special option that is limited to only the line command.
For example here I use it to draw a square positioned at a midpoint:
Another example - here drawing an arc balanced around a midpoint:
It's better to have that one general mechanism that works in all drawing commands, than to try and have a special option that is duplicated in the UI for every command.
Anyway, that is the reason why there is not currently an alternate mechanism for it.
But I have thought some in the past about adding one in just for the line command to help people who haven't learned about using construction lines.
I still may do that, I'm not quite sure - I tend to hesitate quite a bit before adding in additional UI because it tends to be difficult to remove things later and adding in too many unnecessary things generally leads to bloating the UI and making it more complex.
2782.34 In reply to 2782.32
(edit: just seen your last post, well I agree but what about having them inside a group? Maybe for exporting the model and the clines toghether?)
Michael, if you want some kind of help (because you dont have time to) in UI design its also part of my job, I do mockups (bitmap or vector) for web and desktop applications.
Im a graphic designer before being a 3d artist, im totally not a programmer that's why I mostly do mockups.
Speaking of UI the first problem I see is "why blue?" :P It reminds me the horible windows products like office and vista.
Also I know you're not a designer but the MoI website is not as good as MoI is in term of power. Its like having a very good product at is core but a bad packaging, I remember the first time Ive seen MoI and the website ive thought "is that nurbs for kids?" well obviously not but it makes me laugh.
The best UI ive seen are After Effects cs4 (when set to dark), Modo 401, and Nuke wich is pretty strange but not eye distracting.
When I work all the day with MoI my eyes are sometimes hurting, Ive already set up the grid and the background to grey shades :)
Here's one of the latest website design ive worked on (www.lestudiodigital.com) Its strange, the client wanted something colorfull and pro looking. (L.S.D = Le Studio Digital) The center graphic is a mix of stock images and technical drawings.
I do mockups ready to be used by the code guy, I have all in separate layers. So if you need a freelance im here and im free mostly because Im 18 and I still have a lot of time and things to learn (well maybe having a lifetime MoI key for all the upgrades would do the trick) This example is bitmap but I can do exactly the same in vector (except for the center graphic obviously)
There's no watermarks, I hate them :D
2782.35 In reply to 2782.34
Hi DesuDeus,
It's very kind of you to offer!
But actually there are some benefits in taking time and kind of "growing" the UI more slowly rather than too rapidly, it can actually make for a better long term outcome.
A lot of the most important aspects in MoI are actually more about workflow and usability rather than so much focused on just the graphic design of the UI actually, although that is nice to have tuned up too of course.
Because it is a nice color? :)
I know it is much more in vogue to have dark colors, but actually I don't really like that as much, I find it kind of depressing.
But tastes vary a lot!
You should have seen what I had at first, the current one is a pretty big improvement! :)
But yes, I have not really had much time to spend on the web site, I wish that I could spend more time working on that as well as the software but there are only 24 hours in the day...
Probably after v2 is released I'll focus at least a little effort on making another pass at tuning it up.
Sounds too dark and depressing - when you're working with something all day, it's nice for it to not feel like you're in a crypt or something... ;)
It's nice when the UI has a somewhat more refreshing and friendly feel to it, or at least an element of that instead of all just darkness...
Don't get me wrong, your example there looks great and very professional! But that's really not along the direction that I like to have for MoI though.
2782.36 In reply to 2782.35
Also, MoI's UI look and feel and colors are "TOTALLY CUSTOMIZABLE"! A great acheivment by the design.
While in its beta state you havnt seen the iterations of "Skins" but they have been done. When it's released maybe a few more will pop up that you like the look of.
I've seen "Pilou" show some different looks. Maybe he can demonstrate here now?
As far as the look I dont think you have to worry. Custom UI is a HUGE plus with MoI! You can even create your own graphics and replace, to make your own "buttons" "tabs" "text" and whatever. Most apps let you choose "Colors". MoI, far superior here :O
Show messages:  1-16  17-36  37-56  57-63
