Mac Parallels/Wacom/MoI Compatibility?
2775.1
Howdy!
I'm a longtime Mac user, and former formZ user. I've grown disenchanted with formZ's high priced upgrades, dongle issues, and general clunkiness, so that has led me to seek alternatives. I like what I've seen of MoI so far, but have some questions.
My Mac is a Core 2 Duo 2.93 GHz iMac with 4 GB installed RAM. I'm looking at running Windows XP Home Edition through Parallels 4.0. I have an older Wacom Intuos tablet.
Does anyone have experience with a similar set up and MoI? I'm hoping to get some feedback from users before I spend $250 for Windows and Parallels, just so I can try out MoI. Any thoughts, comments, etc would be greatly appreciated.
Thank you!
Karl
2775.2 In reply to 2775.1
Hi Karl,
I would prefer to use on an iMAC -> XP/Vista/Windows 7 only with Boot Camp. (available on the OS X Leopard installation DVD )
http://www.apple.com/support/bootcamp/
Parallels and VMWware Fusion... works well in the "Office area", but for professionel CAD/graphic/... applications -> unsuitable.
Example:
When I am running Vmare Fusion on my MAC PRO (OS Leopard) with both Windows 7 and windows vista the computer is terribly slow.
When I checked the graphics card on my virtual machine I am NOT getting the full power of my ATI Radeon (512mb of Vram).
Anybody know how to allocate more vram for my virtual machine?
Is this even possible?
Under the settings you can do it for memory, HD, etc. but not much can be done for the video card.
...all of the virtual video ram comes from your system's RAM...
VMware does not touch your physical video card at all.
And the maximum video ram you can allocate is 256 MB.
Note that we don't use video memory in the same way that a real video card does.
It's possible for an application to load much more than 128mb of data into your host video card despite having only 128mb visible to the guest,
we've seen games that load upwards of 400-500 mb of data into the host video card.
We sorta use the memory as a temporary place to put things until the host can pick them up and load them into host vram.
Ralf
2775.3 In reply to 2775.1
Hi Karl, I have not tested it myself but I have heard from a few people recently that MoI is working for them using Parallels on a Mac.
There was one recent forum post here that mentioned it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2749.1
Just make sure you are using the most recent 4.0 version of Parallels - older versions did not necessarily allow for programs to access 3D display functions but that seems to be handled much better in Parallels 4.0 now.
Windows XP home edition is fine for running MoI.
2775.4
You can only use Parallel, and not VMFusion to run moi, because VMFusion does not emulate DirectX.
At least the last time I checked (there might have been an update).
I would download the latest version of parallel, and install the RC of Windows7. This windows versionis 'free' until next spring, which gives you enough time to see if you like it. I can't remember how long the parallels trial runs for, but it should also give you enough time to try before buying.
I have run Moi under parallel on an octocore macpro. There is a little time offset when you navigate the view, but otherwise it works fine.
Also there is always the option of using bootcamp, but I think it is better if possible to just run moi under Windows and do rest in OSX, if you are used to working in the later.
Good luck
2775.5 In reply to 2775.1
If I were you I would download the mac beta of rhino and see what you think of that. It is not complete, but it is pretty usable, and it will be free until they wrap up the beta process, which could be some time...
Rhino is not a hundred miles away from moi, and is a more mature product, so you may get what you are after without running windows etc etc
Both Rhino and Moi are fantastic products...
cheers
rabbit
2775.6 In reply to 2775.5
Hi rabbit, that's a good tip, but I'd have to say describing the Mac version of Rhino as "mature" is very misleading though.
Certainly that description would apply to the Windows version of Rhino, but to the current Mac one, no way...
But it would be worth checking out, sure.
2775.7
Thanks to all for your helpful suggestions.
Are there any known issues with the Wacom Intuos graphic tablet and Bootcamp/Parallels/MoI?
Thankl you!
Karl
2775.8 In reply to 2775.7
Hi Karl & all,
Please understand me right, it`s not my ego...or a provocation...or against PARALLELS / VMWare
We make daily support for a CAD application, and our expiriencies are:
PARALLELS and VMWare.....others
They will get better and better, that's not a question,
but for the daily & professional work/usage with 3D CAD or graphic design,
unfortunately still not suitable. ( Only for hobby usage, or some games...)
Boot Camp
With Boot Camp, the second OS running natively. ( OS X and Windows )
Disadvantage in order to change the OS -> A reboot is necessary.
Workaround: An external FAT 32 HDD
All Windows drivers work well, also our small BAMBOO`s :)
2775.9 In reply to 2775.7
Hi Karl,
I'm running MOi latest beta, on an Imac Intel (2gb ram) 1st generation with parallels 3.
Work fine, if you do very very funky things you can restart on bootCamp side.
Also parallels can see the bootcamp disk drive partition !
Look M'ma what i have done with moi ! :)
-TBahn
