Format SAt
All  1-11  12-18
2761.12 In reply to 2761.10
>>As for tests - try importing one of your own more or less complex models into revit (trial if you still have it) and see the result.
Hi Igor,
I have not as yet seen any problems with sat export from MOI. Those exported sat files are imported into various other applications, such as Viacad Pro(Acis), solid_works and solid_edge, I have seen/hear no problem. Inventor 2010 does import sat files from MOI ok (certainly on the models made), but step files still cause it issue (even though I know the step files are OK and import into every other application checked).
Please do post an example file so a check can be made on its import into various other applications.
Regards,
- Steve
2761.13 In reply to 2761.12
Hi Steve ! Welcome back :)
That's surprising, I find *.step to be the most robust translator when importing into Industrial 3d CAD programs, I find it the next best translator to parasolid *.x_t
2761.14 In reply to 2761.10
Hi Igor, for the next MoI v2 release I've updated the SAT export so that it will split closed surfaces (for example cylinders) into 2 halves rather than having a single closed surface that has a "seam edge" in it.
That appears to be one of the major problems with Revit, that it gets confused pretty easily when trying to read in surfaces like that.
I don't know yet if it will solve the particular problems you ran into because I did not receive any files from you to test with... But it appears to make a big difference with getting stuff over better.
It will be possible to turn off closed surface splitting by a setting in the moi.ini file.
2761.15 In reply to 2761.13
Hi Danny,
Inventor will not import an exported Step file from MOI, even a cube gives error. Step AP203 from SW imports (on quick tests) OK.
I have been looking at importing a Sat file from Viacad(Acis) into Revit(demo), anything above sat V7 gives error, below V7 does import, but not an expected result, as example, a cube is imported as a rounded cube.
Looking at Inventor, that will import sat from MOI and sat V7 (and below) from Viacad(sat above V7 from Viacad is reported as "not supported")
- Steve
Message 2761.16 deleted 30 Jul 2009 by IGOR
2761.17 In reply to 2761.14
Hi Michael!
That's a huge step forward with sat export!!!
I tested it on 2009 ver and it went in perfectly!!! Just like rhino now!))
I now can't wait till you release next beta cause next week i start a new project and might already start using MoI heavily..
btw you mentioned that it will be an option in moi and now you say that it will be switched on by default.. Will such spliting affect performance of a MoI model? when it will be preferrable not to have it switched on?
Igor
2761.18 In reply to 2761.17
Hi Igor,
Well, the main thing is it alters topology - things like edges that cross the split line will be split into 2 edges rather than staying as one long edge.
It can be nice to keep edges longer when possible, it makes some kinds of operations that work by selecting edges such as fillets to be handled easier since there are less pieces to pick.
I don't think that you will have much choice but to leave it enabled for going into Revit though, since Revit just does not seem to handle closed surfaces.
Show messages: All  1-11  12-18
