360view
All  1-3  4-7
2760.4 In reply to 2760.1
2760.5
Hello Guys Thanks for your help!
Michael the autorotate2 plugin is great. I thought of this. Wonderful! Just that would be better for me in paralel view because of projections.
2760.6 In reply to 2760.5
Hi andras,
In MoI v2 you can change the 3D view to be a parallel projection - go to Options > View > 3D view projection. By default it is perspective, but you can change it to parallel there.
You can also set up some keyboard shortcuts to orient the 3D view to the Top, Front, or Right, see this thread:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2104.1
You can also control the 3D view by setting the angles under Options > View > 3D view angles .
So probably by combining those together you could set up your 3D view to be a parallel front view, and then use the auto rotate plugin to get the kind of animation that you want I think.
2760.7 In reply to 2760.6
Thank You! :)
Show messages: All  1-3  4-7
