Draw at intersections
All  1  2-6
2755.2 In reply to 2755.1
Hi Pilou, try selecting all the curves and running Construct / Curve / Isect to generate point objects at all the intersections.
Then use the CopyToPoints command that Petr made:
http://kyticka.webzdarma.cz/3d/moi/#CopyToPoints
The first stages of that CopyToPoints command is similar to the regular Transform/Copy, that you select objects to copy and then a base point on the object. But then you select point objects as the target locations rather than clicking, so select the points that were made in the intersect command for that stage.
2755.3 In reply to 2755.2
Very cool!
Excellent!
2755.5 In reply to 2755.2
I suppose since you were looking into adding the ability to add a style to a point that would then have it be available with "Types" also in the scene browser?
2755.6 In reply to 2755.5
There is no "point" in the browser but you can invert selection by Plugin
so some tricky selection can be made :)
Show messages: All  1  2-6
